Brucifer Posted April 29, 2016 Report Share Posted April 29, 2016 Running the front wipers sometimes creates a squeaking sound. It's not the blades since I happens with two different styles. Anyone else have this issue? Do I need to remove the intake screen where the arms come out and lube something? Quote Link to comment Share on other sites More sharing options...
edge0799 Posted April 29, 2016 Report Share Posted April 29, 2016 yeah i have a 2007 and I had the same issue watched a video on youtube get a wrench or some thing to grip the wiper arm and tweek it a little bit look it up on youtube works like a charm 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 30, 2016 Report Share Posted April 30, 2016 I find that it's nothing more that a film on the windshield and oxidized blades. Windshields tend to accumulate and oil film from the road, and the film attracts dirt to stick to it. The blades have to streak across this film. Cleaning the windshield will help. Vinegar is good for this, cheap too. Blades, being rubber exposed to the road grime, salt and sunlight tend to develop an oxidation, making them lose some of theur flexibility. I wipe mine with a eyeglass cleaner wipe. Same wipe you use for your sunglasses. Clean your sunglasses then clean your blades. The alcohol will remove the oxidation film. This should stop any squeeking. 1 Quote Link to comment Share on other sites More sharing options...
Brucifer Posted May 1, 2016 Author Report Share Posted May 1, 2016 I should of been more clear that it was more of a metallic squeak than anything else. Perused the YouTube vids and came away with oiling the pivot point and spring on the arm of the wiper. Did run a bit of oil down the shaft of the wiper (under the main nut), but I think it was more a case of a rusty hinge than anything else. Have some more rain coming this week, so I should be able to really test them. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 1, 2016 Report Share Posted May 1, 2016 Probably more likely a dry joint where the shaft comes through the cowling (hinge barely moves when in use). You might try using penetrating oil on the shaft. Quote Link to comment Share on other sites More sharing options...
Brucifer Posted July 21, 2016 Author Report Share Posted July 21, 2016 Took the top cowl off. Tri-Flowed everything. Tri-Flowed all joints on arms. Now almost worse than before: https://www.youtube.com/watch?v=P3FkNfxnvPU Quote Link to comment Share on other sites More sharing options...
fishx65 Posted July 22, 2016 Report Share Posted July 22, 2016 Now that's irritating!!!! I would take the arms completely off and run the wipers to see if the sound is still there. Quote Link to comment Share on other sites More sharing options...
Brucifer Posted December 19, 2016 Author Report Share Posted December 19, 2016 Final update. On the passenger side arm, there is a spring that holds the arm against the windshield. It's the joint that bends when you want to lift the arm away. Anyhoo, when the arm is in the down position, the post side of the spring extends out and makes contact with the glass. I tried using pliers to squeeze the spring back, but that didn't go well, so I wrapped the area with electrical tape until I can get to the dealership to buy a replacement arm. I poked around to get an idea as to what an arm would cost, but most listings are for the rear arm, not the front. I'm going to be guessing in the $25-$30 range. If it's more than that, I'll try to get a part number and do some deeper digging. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted December 19, 2016 Report Share Posted December 19, 2016 http://www.fordparts.com/Commerce/PartDetail.aspx?n=LN1tT%2bCeZmK%2bdpoBO8tEmQ%3d%3d&id=398806458&m=2&search=true&year=2007&make=Ford&model=Edge 1 Quote Link to comment Share on other sites More sharing options...
