lpgao Posted April 27, 2016 Report Share Posted April 27, 2016 Hi Guys, can someone tell me how to turn on outside air only without heating or AC working? Sometimes I could have air direct from outside to my face, but many times heater or AC on. But I just need fan on to bring outside air only. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted April 27, 2016 Report Share Posted April 27, 2016 Make sure the AC button and recirculate are off. Select VENT as the air source and turn temperature all the way down. Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted May 8, 2016 Report Share Posted May 8, 2016 Recirculate button off. That's pretty much it. Quote Link to comment Share on other sites More sharing options...
lpgao Posted June 19, 2016 Author Report Share Posted June 19, 2016 Make sure the AC button and recirculate are off. Select VENT as the air source and turn temperature all the way down. Thanks for normcloutier kind reply. But how to select "VENT"? I dont see this option. I really need do this because now days outside air is cool but inside hot and there is no need AC. However blow air not is as cool as outside while lower down window. If we can not use outside fresh cool air I will say the AC system design is stupid waste energy. Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted June 19, 2016 Report Share Posted June 19, 2016 (edited) What year is your vehicle? I'd imagine it's different throughout the years. Edited June 19, 2016 by DRbillZ Quote Link to comment Share on other sites More sharing options...
lpgao Posted June 20, 2016 Author Report Share Posted June 20, 2016 What year is your vehicle? I'd imagine it's different throughout the years. It is 2011 limited. But when driver can not choose to blow ioutside air only? Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted June 20, 2016 Report Share Posted June 20, 2016 Does your car have a recircilation switch? Quote Link to comment Share on other sites More sharing options...
lpgao Posted June 20, 2016 Author Report Share Posted June 20, 2016 Does your car have a recircilation switch? yes it is but it is always off. So my question is can drive choose fan only from outside fress air not using climate control? Quote Link to comment Share on other sites More sharing options...
TheWizard Posted June 20, 2016 Report Share Posted June 20, 2016 normcloutier is correct... turn off recirculation, turn off A/C, set temperature low (at least as low as the outside temp to prevent heat), and select the dash vents as the output. It's probably not labeled "Vent" but it's the setting that blows air through the dash vents usually designated by an icon that shows an arrow pointing at the upper body: Do not select defrost as that will activate the air conditioning even when you have it off. The A/C is used to dry the air to the windshield for defrosting. Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted June 20, 2016 Report Share Posted June 20, 2016 Seriously this isn't rocket science. Recircilation off= outside air Air blowing at face= air blowing at face... Quote Link to comment Share on other sites More sharing options...
