2013 Edge 90k needs a new turbocharger
Cbdude
I had the check engine light go on and the fault code was P0299 turbo under boost code. I took it into the dealer and they said I needed a new turbine replacement. My fault for recently bragging on how I had no maintenance so far on my Edge. I'm disappointed that such a high dollar item just broke. I do a lot of NY thruway miles so while high mileage; it's easy mileage.
Did you see a drop in power, or any oil being burnt? Most of the time if an impeller goes you will notice those symptoms.....as well as some strange noises, unusually loud whine, or ticking.
  • 5 years later...
