Edge Sport Harsh Suspension
phils
  On 4/23/2016 at 12:31 AM, phils said:
Like everything about the 2016 Sport except the harsher ride. Is there any way to soften ride?
So other than maybe posting in the wrong section, not that it is a big deal to me as I am still trying to understand a somewhat confusing site (but I'm old) .........you haven't said what size tires you have. I think that the 40 aspect ratio (is that the right word?) has a stiffer side wall than the 50 series tires. :)
Just a question. Can anyone tell me the exact difference in the suspension components and assembly between a 2016 Edge Sport and a 2016 Edge Limited/SEL/SE? Is there actually any difference? Different shocks? Different LCA's and struts? Or is SPORT merely a name? and a (more horse power) engine? Really is there a difference? Prove me wrong in the assumption that all levels do not use the same suspension components.
You can pretty easily do a search on a place like fordparts.com and see that there are different part numbers for shocks on a Sport.
Thanks for the comments about my concern. All have been helpful. Unit does have the 20" inch wheels which was difficult for dealer to locate, Ford likes to add 21's because sticker rises another $900 plus.(more profit) I am becoming more accustomed to ride the more I drive. Will look at part numbers between Sport versus Limited .
Chassis SE, SEL and Titanium Front suspension Independent, MacPherson struts and L-shaped lower control arm with isolated subframe and stabilizer bar Front shocks Gas-pressurized, hydraulic, twin-tube Rear suspension Independent integral link, isolated subframe and stabilizer bar Rear shocks Gas-pressurized, hydraulic, twin-tube or monotube Brakes Power 4-wheel disc with Anti-lock Braking System (ABS) and AdvanceTrac® with Roll Stability Control™ (RSC®) Steering Electric Power Steering Rack-and-Pinion
Chassis Sport Front suspension Independent, MacPherson struts and L-shaped lower control arm with isolated subframe and stabilizer bar Front shocks Gas-pressurized, hydraulic, twin-tube Rear suspension Independent multi-link suspension with trailing blade control arms, isolated subframe and stabilizer bar Rear shocks Gas-pressurized, hydraulic, monotube Brakes Power 4-wheel disc with Anti-lock Braking System (ABS) and AdvanceTrac® with Roll Stability Control™ (RSC®) Steering Electric Power Steering Rack-and-Pinion
Question is then WHAT is the difference between the two part numbers? Physical design to accommodate the larger wheels or a better firmer shock? In this case it is assumed the fit will be the same since the design has not changed. Interchangeable? between models?
