phils Posted April 23, 2016 Report Share Posted April 23, 2016 Like everything about the 2016 Sport except the harsher ride. Is there any way to soften ride? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 23, 2016 Report Share Posted April 23, 2016 Smaller rims would help. (Wouldn't look as cool however). Quote Link to comment Share on other sites More sharing options...
Old Ray Posted April 23, 2016 Report Share Posted April 23, 2016 Maybe try lower the air pressure in the tires a bit or install springs and struts from a non-sport model? My 2015 Ti rides very nice ......and yet I have ordered a 2016 sport and will live happy with the ride. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 23, 2016 Report Share Posted April 23, 2016 If you have the optional 21" wheels maybe try the 20" wheels instead like what enigma-2 suggested. Also with the 21" wheels you might have the summer tire option, which are sportier & hence I think would be harder. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted April 25, 2016 Report Share Posted April 25, 2016 Don't get a sport then. Suspension on anything sport related is going to be harsher 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted April 25, 2016 Report Share Posted April 25, 2016 Sometimes they forget to lower the air pressure before delivery. The factory sets it high so the tires aren't as likely to flatspot during shipment. Our MKX with the 21" wheels were 4-5 psi too high on delivery and it does affect the ride. 1 Quote Link to comment Share on other sites More sharing options...
Old Ray Posted April 28, 2016 Report Share Posted April 28, 2016 Like everything about the 2016 Sport except the harsher ride. Is there any way to soften ride? So other than maybe posting in the wrong section, not that it is a big deal to me as I am still trying to understand a somewhat confusing site (but I'm old) .........you haven't said what size tires you have. I think that the 40 aspect ratio (is that the right word?) has a stiffer side wall than the 50 series tires. Quote Link to comment Share on other sites More sharing options...
luminator Posted April 28, 2016 Report Share Posted April 28, 2016 Go figure I thought the suspension was a bit on the soft side still on the sport and wanted to tighten it up. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted April 28, 2016 Report Share Posted April 28, 2016 Go figure I thought the suspension was a bit on the soft side still on the sport and wanted to tighten it up. Me too! Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 29, 2016 Report Share Posted April 29, 2016 Just a question. Can anyone tell me the exact difference in the suspension components and assembly between a 2016 Edge Sport and a 2016 Edge Limited/SEL/SE? Is there actually any difference? Different shocks? Different LCA's and struts? Or is SPORT merely a name? and a (more horse power) engine? Really is there a difference? Prove me wrong in the assumption that all levels do not use the same suspension components. Quote Link to comment Share on other sites More sharing options...
Waldo Posted April 29, 2016 Report Share Posted April 29, 2016 Just a question. Can anyone tell me the exact difference in the suspension components and assembly between a 2016 Edge Sport and a 2016 Edge Limited/SEL/SE? Is there actually any difference? Different shocks? Different LCA's and struts? Or is SPORT merely a name? and a (more horse power) engine? Really is there a difference? Prove me wrong in the assumption that all levels do not use the same suspension components. You can pretty easily do a search on a place like fordparts.com and see that there are different part numbers for shocks on a Sport. Quote Link to comment Share on other sites More sharing options...
phils Posted April 29, 2016 Author Report Share Posted April 29, 2016 Thanks for the comments about my concern. All have been helpful. Unit does have the 20" inch wheels which was difficult for dealer to locate, Ford likes to add 21's because sticker rises another $900 plus.(more profit) I am becoming more accustomed to ride the more I drive. Will look at part numbers between Sport versus Limited . Quote Link to comment Share on other sites More sharing options...
akirby Posted April 29, 2016 Report Share Posted April 29, 2016 The dealers order the 21" wheels, not Ford. If they're ordering more 21" wheels then customers are asking for more 21" wheels. Quote Link to comment Share on other sites More sharing options...
davidceder Posted April 29, 2016 Report Share Posted April 29, 2016 Chassis SE, SEL and Titanium Front suspension Independent, MacPherson struts and L-shaped lower control arm with isolated subframe and stabilizer bar Front shocks Gas-pressurized, hydraulic, twin-tube Rear suspension Independent integral link, isolated subframe and stabilizer bar Rear shocks Gas-pressurized, hydraulic, twin-tube or monotube Brakes Power 4-wheel disc with Anti-lock Braking System (ABS) and AdvanceTrac® with Roll Stability Control™ (RSC®) Steering Electric Power Steering Rack-and-Pinion Chassis Sport Front suspension Independent, MacPherson struts and L-shaped lower control arm with isolated subframe and stabilizer bar Front shocks Gas-pressurized, hydraulic, twin-tube Rear suspension Independent multi-link suspension with trailing blade control arms, isolated subframe and stabilizer bar Rear shocks Gas-pressurized, hydraulic, monotube Brakes Power 4-wheel disc with Anti-lock Braking System (ABS) and AdvanceTrac® with Roll Stability Control™ (RSC®) Steering Electric Power Steering Rack-and-Pinion 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 30, 2016 Report Share Posted April 30, 2016 You can pretty easily do a search on a place like fordparts.com and see that there are different part numbers for shocks on a Sport. Question is then WHAT is the difference between the two part numbers? Physical design to accommodate the larger wheels or a better firmer shock? In this case it is assumed the fit will be the same since the design has not changed. Interchangeable? between models? Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 30, 2016 Report Share Posted April 30, 2016 From the 2015 Edge Source Book: Sport-tuned Suspension: Final drive ratio of 3.16:1 with FWD, 3.39:1 when equipped with AWD Includes revised front strut tuning, rear spring rates and rear jounce bumper Quote Link to comment Share on other sites More sharing options...
