Mustangmike72 Posted April 14, 2016 Report Share Posted April 14, 2016 I just bought a 2014 last weekend and the passenger side 12v power socket is missing the plastic cover. I'm assuming the whole socket has to be pulled out to replace the cover, and I'm assuming the best way to pull the socket is by unbolting the center console and moving it back. Or does someone know of a better way? Also, i would appreciate a picture or a PDF of the shop manual of where the bolts are for the console. Thank you for your time Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 14, 2016 Report Share Posted April 14, 2016 You need a special tool to remove the socket from the front, without needing to remove panel. I faced a similar problem for the rear (2nd row) power point. I removed the whole trim piece & even then it was quite difficult to remove the socket. I remember I had to break it off. Just shows how life is so much easier with the right tools. I found this tool on Amazon, I remember the Ford tool looks similar, but I can't be sure. http://www.amazon.com/Dorman-56457-Cigarette-Lighter-Removal/dp/B00G3YYSLE 1 Quote Link to comment Share on other sites More sharing options...
TheWizard Posted April 14, 2016 Report Share Posted April 14, 2016 I just got that tool from Amazon for my Mustang. It works but you still have to pull pretty hard to get the socket to come out. That was surprising because I was under the impression you would use the tool to turn the socket and that it would then pull out easily (like a twist-lock setup). But you actually just use the tool to hook into the slots in the sides of the socket and then give it a good yank to pull it straight out. Make sure you disconnect the battery because the tool is metal and you could accidentally push it far enough into the socket to contact the positive connection at the bottom and short it out. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 14, 2016 Report Share Posted April 14, 2016 Make sure you disconnect the battery because the tool is metal and you could accidentally push it far enough into the socket to contact the positive connection at the bottom and short it out. Pull the fuse, less hassle. Quote Link to comment Share on other sites More sharing options...
TheWizard Posted April 14, 2016 Report Share Posted April 14, 2016 That's true for the Edge because the power point fuses are in the fuse box under the hood. On my Mustang the fuse is in the interior fuse box behind the right kick panel which is difficult for an old guy like me to access. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 14, 2016 Report Share Posted April 14, 2016 The power point fuses are in the underhood fuse box, in which case the OM says to disconnect battery first before replacing. Don't know if that's really necessary or not, but that's what the OM says. Hate the thought of having to go through the PCM relearn just for this, but ... 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 14, 2016 Report Share Posted April 14, 2016 That's true for the Edge because the power point fuses are in the fuse box under the hood. On my Mustang the fuse is in the interior fuse box behind the right kick panel which is difficult for an old guy like me to access. Ya, I feel your pain brother. But.... be damned if I'm going quietly. Even if I have to spend the evening cuttled up to a heating pad and a bottle of Tylenol. Why I remember when I .... wait, I forgot. lol 1 Quote Link to comment Share on other sites More sharing options...
Mustangmike72 Posted April 14, 2016 Author Report Share Posted April 14, 2016 Right on thank you everyone! This is the first modern vehicle ive owned, I assumed the plug was held in place by a large nut like all my old cars. I'm relieved I don't have to start pulling panels just for a dumb power point Quote Link to comment Share on other sites More sharing options...
Mustangmike72 Posted April 14, 2016 Author Report Share Posted April 14, 2016 Also, it was mentioned if you unplug the battery you have to let the PCM "relearn," just for future reference what does that involve, is it as simple as key on for a couple minutes or will I need to plug in a diagnostic scanner? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 14, 2016 Report Share Posted April 14, 2016 It's fairly straightforward, and as specified in the OM pg 280 or so under the Maintenance section: When the battery is disconnected or a new battery installed, theautomatic transmission must relearn its adaptive strategy. As a result ofthis, the transmission may shift firmly when first driven. This operation isconsidered normal and will fully update transmission operation to itsoptimum shift feel.If the battery has been disconnected or a new battery has been installed,the clock and the preset radio stations must be reset once the battery isreconnected.Note: Always dispose of automotive batteries in a responsible manner.Follow your local authorized standards for disposal. Call your localauthorized recycling center to find out more about recycling automotivebatteries.Because your vehicle’s engine is electronically controlled by a computer,some control conditions are maintained by power from the battery. Whenthe battery is disconnected or a new battery is installed, the engine mustrelearn its idle and fuel trim strategy for optimum driveability andperformance. To begin this process:1. With the vehicle at a complete stop, set the parking brake.2. Put the gearshift in P (Park), turn off all accessories and start theengine.3. Run the engine until it reaches normal operating temperature.4. Allow the engine to idle for at least one minute.5. Turn the A/C on and allow the engine to idle for at least one minute.6. Drive the vehicle to complete the relearning process.• The vehicle may need to be driven 10 miles (16 km) or more torelearn the idle and fuel trim strategy.• Note: If you do not allow the engine to relearn its idle trim, the idlequality of your vehicle may be adversely affected until the idle trim iseventually relearned. Probably more critical to do if you are driving the Edge for very short trips normally. But if you routinely do city/highway trips, it may take longer, but will relearn as you drive. The Emissions drive cycle is touchier and should be followed strictly, if you disconnect the battery and are within a few days/less than 200 miles (city/hwy mix) of getting the Edge tested. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 14, 2016 Report Share Posted April 14, 2016 (edited) Readiness for Inspection/Maintenance (I/M) Testing pg 173Some state, provincial and local governments may haveInspection/Maintenance (I/M) programs to inspect the emission controlequipment on your vehicle. Failure to pass this inspection could preventyou from getting a vehicle registration.If the service engine soon indicator is on or the bulb does notwork, the vehicle may need to be serviced. See On-boardDiagnostics (OBD-II) in this chapter.Your vehicle may not pass the I/M test if the service engine soonindicator is on or not working properly (bulb is burned out), or if theOBD-II system has determined that some of the emission control systemshave not been properly checked. In this case, the vehicle is considerednot ready for I/M testing.If the vehicle’s engine or transmission has just been serviced, or thebattery has recently run down or been replaced, the OBD-II system mayindicate that the vehicle is not ready for I/M testing. To determine if thevehicle is ready for I/M testing, turn the ignition key to the on positionfor 15 seconds without cranking the engine. If the service engine soonindicator blinks eight times, it means that the vehicle is not ready for I/Mtesting; if the service engine soon indicator stays on solid, it means thatthe vehicle is ready for I/M testing.The OBD-II system is designed to check the emission control systemduring normal driving. A complete check may take several days. If thevehicle is not ready for I/M testing, the following driving cycle consistingof mixed city and highway driving may be performed: 15 minutes of steady driving on an expressway or highway followed by 20 minutes of stop-and-go driving with at least four 30-second idle periods. Allow the vehicle to sit for at least eight hours without starting theengine. Then, start the engine and complete the above driving cycle. Theengine must warm up to its normal operating temperature. Once theengine is started, do not turn off the engine until the above driving cycleis complete. If the vehicle is still not ready for I/M testing, the abovedriving cycle will have to be repeated. Edited April 14, 2016 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
Mustangmike72 Posted April 15, 2016 Author Report Share Posted April 15, 2016 Thank you, yeah I'm still waiting for the OM to come in the mail, guess I could have waited a couple days and read it myself! Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 15, 2016 Report Share Posted April 15, 2016 If the battery has been disconnected or a new battery has been installed, the clock and the preset radio stations must be reset once the battery is reconnected. I don't know why they still state this, but at least since my 2008 Taurus & now 2011 MKX didn't get their Radio presets reset on a battery disconnect/change! 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 15, 2016 Report Share Posted April 15, 2016 The power point fuses are in the underhood fuse box, in which case the OM says to disconnect battery first before replacing. Don't know if that's really necessary or not, but that's what the OM says. Hate the thought of having to go through the PCM relearn just for this, but ... On my OM it states that the battery be disconnected on servicing the high amperage fuses. I imagine that this is because should the circuit is shorted, a high amperage fuse would get super hot as soon as it was replaced. A 20 amp fuse covering the power points is no worse than the 20 amp fuses in the interior panelbox. Under the conditions stated (wants to remove a working power point - no short), I wouldn't hesitate to just pull the fuse 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 15, 2016 Report Share Posted April 15, 2016 (edited) Here's where you can buy the correct Ford tool to remove the power point socket. https://rotunda.service-solutions.com/en-US/Pages/ItemDetail.aspx?SKU=501-039 Instructions: http://ww2.justanswer.com/uploads/KE/kennyz1963/2013-05-23_125607_powerpoint.pdf If you can gain access from behind, you can remove it without tools. https://m.youtube.com/watch?v=Cjfv67DiZNU Edited April 15, 2016 by enigma-2 2 Quote Link to comment Share on other sites More sharing options...
Mustangmike72 Posted April 15, 2016 Author Report Share Posted April 15, 2016 Excellent, seems easy enough, sure as heck beats pulling out panels. Thank you! Quote Link to comment Share on other sites More sharing options...
TheWizard Posted April 15, 2016 Report Share Posted April 15, 2016 I'm pretty sure you'd find that the Dorman (aftermarket) tool is the same as the Ford tool except for being $8 cheaper. All power sockets are the same diameter because they have to fit standard plugs so the tool to remove them would have to fit the same way. I even found that the socket included in the kit from Amazon was the same as the Ford original I pulled from my dash despite being listed for GM vehicles. Quote Link to comment Share on other sites More sharing options...
