Enhanced Active Park Assist Fail?
Anyone have issues with this feature? Half the time, it backs me into a space perfectly. The rest the time, it parks within INCHES of the car next to me, then smugly chimes and tells me its job is done. As in, so close to the car next to me that I would not be able to open the door at all. Just wonder what the issue is. I've also yet to determine if the system tries to center the car in the lines or just between the cars on either side.
At any rate, it's a quirky system. The regular parallel park assist works great, however.
Edited by cjh
My assumption is it centers the car between the cars on either side. I've tried it in an empty parking lot, and I don't recall it finding any spaces (even though there was nothing but spaces)
I don't think it can see the lines, just detect the cars/objects on either side.
I can definitely see an entire thread of pictures showing comically bad parking jobs as performed by the park system :)
But overall, yes, I agree it generally works as advertised if not a bit quirky at times.
  • 4 months later...
Ive had it try and park me into a spot that had a car in it already, several times. (parallel -6 , perpendicular - 7). Sometimes it tells me to keep backing up even though I couldn't fit my hand between the bumper and the other vehicle. I've lost all trust in the system, I only use it when there is enormous amounts of room and no one around.
backing in is quirky, though I've used it to parallel park in extremely tight spaces just for shits and giggles. we staged 2 cars and kept putting them closer and closer to see when the edge wouldn't park. I've also used it to parallel park A LOT, for the wow factor. Usually have soldiers with me and they all want to see it
  • 5 weeks later...
I just tried it today, I stopped the car right the way after it found the spot, when it reverse during parallel parking, it goes too fast almost hit the car behind. The second time I tried it does again! It still wants to go after the red warning beat! I never trust this again
Edited by TweetyEdge
I have NEVER had an issue parallel parking, we even staged it at work, we would let it park, then I'd pull out and they would move one of the cars closer till it wouldn't find the spot anymore, that way I could gauge what it would and wouldn't park into. I will mention, if there's not a defined curb, it will throw it all out of wack and probably hit a vehicle.
No perpendicular...well that's still a work in progress and shouldn't even be offered. I think a blind person with a spotter could back into a spot faster.
What do you mean by it goes too fast? you're supposed to be controlling the brake & accelerator pedals. I think you didn't read manual nor the instructions on the screen!
