pilotdog68 Posted April 12, 2016 Report Share Posted April 12, 2016 I have a 2007 FWD with 112k miles. Right at 500rpm you can feel vibration in the steering wheel and there is an audible low rumble, almost like a bass note if I had subs installed. I just bought it used so I thought it might need a tune up, so I changed the spark plugs (old ones were around .075") and ran 2 bottles of Techron, but that made no difference. The idle isn't actually rough (and no error codes), I think it just happens to be the right frequency to resonate the interior body panels making it very loud on the inside, but quiet and smooth on the outside. Increasing rpms up to 600 or 700 makes it go away completely, which I think rules out the torque converter because that should vibrate more under more stress, right? I'll try to check for motor mounts next, as that's the only thing I can think of. How much movement in the mounts is 'normal'? And wouldn't I notice some other symptoms if it was the mounts? It probably isn't much to be worried about, but it really is annoying at red lights or just idling in a parking lot waiting for someone. At all other RPMs she's as smooth as as can be. (I also replied to an old topic that was in the 2008 specific forum, but I think this could be an issue other models years experienced) Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 12, 2016 Report Share Posted April 12, 2016 I had a broken motor mount on an older car. Some noise and vibration like you described. Had the mount replaced with a NAPA version and it was terrible. Very noisy and bibration. Had them take it out and replace with Motorcraft. Like new. My opinion, motor mount broken. 1 Quote Link to comment Share on other sites More sharing options...
pilotdog68 Posted April 12, 2016 Author Report Share Posted April 12, 2016 On RockAuto it seems they only have "Right Front" listed for the mount by a few different manufacturers. I can't believe there is only one mount, how many motor mounts are there really? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 12, 2016 Report Share Posted April 12, 2016 Maybe you can hop over to macbwt's and he'll take a look He's got firsthand familiarity with motor & trans mounts! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 12, 2016 Report Share Posted April 12, 2016 Look at parts diagrams/numbers here: https://secure.revolutionparts.com/levittown-ford/auto-parts/2007/ford/edge/sel-trim/3-5l-v6-gas-engine/engine-cat/engine-and-trans-mounting-scat No. Part # Part # / Description List Price Price 1 8T4Z-6038-A 8T4Z-6038-A / FRONT MOUNT, RIGHT $175.90 $119.26 2 7A1Z-6038-AA 7A1Z-6038-AA / FRONT MOUNT, LEFT $136.23 $92.37 3 8M8Z-6038-A 8M8Z-6038-A / ENGINE BRACKET, RIGHT $55.67 $37.74 4 8T4Z6031B 8T4Z6031B / ENGINE BRACKET, LEFT - - 5 -W711873-S439 -W711873-S439 / ENGINE BRACKET BOLT $6.57 $3.72 6 -W711872-S900 -W711872-S900 / ENGINE BRACKET NUT $3.59 $2.02 7 7T4Z-6K075-BA 7T4Z-6K075-BA / UPPER SUPPORT $7.47 $5.06 8 7T4Z-6K075-AA 7T4Z-6K075-AA / LOWER SUPPORT $10.00 $6.78 9 8T4Z6068A 8T4Z6068A / TRANS MOUNT TO 1/10/08 - - 10 7T4Z-6C038-A 7T4Z-6C038-A / HEAT SHIELD $20.78 $14.09 11 7T4Z-6E042-AA 7T4Z-6E042-AA / BRACKET $19.58 $13.28 Quote Link to comment Share on other sites More sharing options...
3500cc Posted April 12, 2016 Report Share Posted April 12, 2016 Back in the day on rear wheel drive cars, there was an easy way to check for broken motor mounts. Have someone you trust put it in drive with foot on brake and give it a little gas but DON'T MOVE THE CAR. You will look at the engine during this to see if the engine jacks up higher than normal. Do this again in reverse gear. You'll know if its not normal movement. Good luck 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 13, 2016 Report Share Posted April 13, 2016 Not saying it is the transmission torque mount, but your Edge has some low miles on it for the Transmission Torque mount or motor mounts to fail. Not that it is not possible for a failure. Easy to check. Hit the E brake and then start putting it into gear fwd and rev then watch the mounts and transmission torque mount. I have two videos showing a failed torque mount on a 2008 and a good mount on a 2011 hope this helps. The drivers side motor mount is located under the air box. Quote Link to comment Share on other sites More sharing options...
pilotdog68 Posted April 13, 2016 Author Report Share Posted April 13, 2016 Not saying it is the transmission torque mount, but your Edge has some low miles on it for the Transmission Torque mount or motor mounts to fail. Not that it is not possible for a failure. Easy to check. Hit the E brake and then start putting it into gear fwd and rev then watch the mounts and transmission torque mount. I have two videos showing a failed torque mount on a 2008 and a good mount on a 2011 hope this helps. The drivers side motor mount is located under the air box. Yep, I've watched your video. I'll see if I can find a helper to record for me to see while I do the same test. I'm just not sure I'll be able to tell if it isn't really obvious. Anything else you think it could be? I'm stumped, and I don't want to do the mounts unless I know for sure they're bad. Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 15, 2016 Report Share Posted April 15, 2016 (edited) I convinced my wife to lay under the car and record video while I drove it back and forth. LOL Just kidding don't do that!!! I just laid the camera facing up or propped it a bit facing up then went for it. The second video I used my gopro which really worked pretty well. by the way that clinking noise with the 2008 video is the right front sway bar link that I discovered was broken. The 2011 test shows how a good condition torque mount should behave. Yep, I've watched your video. I'll see if I can find a helper to record for me to see while I do the same test. I'm just not sure I'll be able to tell if it isn't really obvious. Anything else you think it could be? I'm stumped, and I don't want to do the mounts unless I know for sure they're bad. Edited April 15, 2016 by macbwt 1 Quote Link to comment Share on other sites More sharing options...
