Ghannan Posted April 7, 2016 Report Share Posted April 7, 2016 My right tail light housing is loose at the front. It was recently replaced by the dealer. How do I get access to whatever screws hold it in place? The dealer who did the replacement is quite a drive, and I figure it must be a simple fix. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 8, 2016 Report Share Posted April 8, 2016 Open the tailgate. The two screws are located on an extension on the assembly. After you remove the screws, the tail light is removed by pulling straight out. You may have to wiggle and massage the assembly to get it free. But it will pull free eventually. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 8, 2016 Report Share Posted April 8, 2016 I know this works for 2007-14, same for 2015, enigma? That would be sweet. Quote Link to comment Share on other sites More sharing options...
Ghannan Posted April 8, 2016 Author Report Share Posted April 8, 2016 There appears to be a plastic piece attached to the assembly and to the frame. Is the little square plus in the plastic piece covering a screw of some sort? No screws are visible. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 14, 2016 Report Share Posted April 14, 2016 I know this works for 2007-14, same for 2015, enigma? That would be sweet.No. I failed to see that he had a 2015. Ever since Ford went to LED bulbs, the assembly is no longer user accessible. Best to have the dealer do it ((under warranty). Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 14, 2016 Report Share Posted April 14, 2016 My right tail light housing is loose at the front. It was recently replaced by the dealer. How do I get access to whatever screws hold it in place? The dealer who did the replacement is quite a drive, and I figure it must be a simple fix. Don't know about the 2015, perhaps it just snaps in place. I would be tempted to try pressing on the front of the lens and see if it snaps I'm place. Otherwise, best to run it back to the dealer. Quote Link to comment Share on other sites More sharing options...
