Map light bezel
SailorJack
Not sure on the 15-16 model, but on earlier Edges and most other vehicles, the entire map light housing is press fit into the headliner. All you would need to do is pry your fingers in between the headliner and the light housing and pull down. Can you see any exposed screws or fasteners inside the sunglasses holder area. That would be where they would likely be if there were any fasteners holding it in. There or maybe under the lamp lens(s).
