2007Edge Posted April 6, 2016 Report Share Posted April 6, 2016 My problem is when I turn left on the stop sign, traction control light goes on for a second and car jerks for a second. I noticed this problem only when the weather is cold ( bellow 2-3 C or 38 F). The road is dry and no snow.I had this problem last winter and at first sign of spring and warmer weather I have changed the ABS sensor on the front left wheel.All summer was OK and beginning of the winter it started again. If I press on the gas little bit more sometimes doesn't jerk. Is it faulty sensor or something else?Thanks. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 6, 2016 Report Share Posted April 6, 2016 If the sensor is good and there is no visible dirt/rust contamination on the sensor/in the connector, the next suspect might be a cracked tone ring. Also, make sure the wiring/brake hoses are not binding in that area. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 6, 2016 Report Share Posted April 6, 2016 I would suspect the connector to one of the front wheel speed sensors but that's just a guess. Try cleaning the connectors and reseating. Quote Link to comment Share on other sites More sharing options...
2007Edge Posted April 6, 2016 Author Report Share Posted April 6, 2016 Thanks, I'll check it. Quote Link to comment Share on other sites More sharing options...
2007Edge Posted September 11, 2016 Author Report Share Posted September 11, 2016 Yes,today I was checking other things and I checked the tone ring, it is cracked. I have to replace it soon before winter. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 11, 2016 Report Share Posted September 11, 2016 (edited) Unfortunately, you have to replace the axle to replace the tone ring, IIRC At least one member had posted about this, maybe within the last year EDIT: http://www.fordedgeforum.com/topic/17212-loss-of-power-and-terrible-grinding-while-trying-to-accelerate/?do=findComment&comment=127271 http://www.fordedgeforum.com/topic/17208-trac-ctrl-kicked-in-then-abstracwrench-light/ Edited September 11, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
