Ford Edge 2007-2010 TSS and OSS failures (will happen) symptoms explained
macbwt
The 6F50 has some rather problematic Turbine Shaft Speed and Output Shaft Speed sensors. The symptoms are described in the video and what to do when you have a total failure of the the sensors. There will be no prewarning lights. However the transmission will demonstrate symptoms that will tell you of the pending failure. If your 2007 through 2010 has more than 60K miles on it you are in the area of failure from that point on. Here is the video.
