HID Kit problem
i have a '15 SE and want to upgrade to a hid kit just for my low beam. i have tried 2 kits and get the same issue....hid set comes on after install without the engine started. once the engine is running the lights go out. after some research all i can come up with is the daytime running light system is causing this..tried disabling daytime running lights via the dash still no luck...support from these kit sellers is bad or non existent , they suggested a wiring harness add on, tried that and no luck. anyone with some experience with subject that can help i would really appreciate it, thanks.
Edited by greeneye150
