Lincoln 2013 mkx sync problem
Jackie1010love
But if you test another phone and it works then you know the problem is not with Sync and the problem is your phone. If it fails the same way with a different phone then the problem is probably with Sync.
Try pulling the fuse for Sync if you can find it or disconnecting the negative battery cable for a few minutes to reset everything.
  • 2 months later...
