bmwta Posted March 27, 2016 Report Share Posted March 27, 2016 1) Any issues with the "check engine" light coming on at any time? 2) Has the 3rd to 4th gear shift lag at full throttle improved over time?3) If I wanted to add a K&N filter, would LMS need to know about it to adjust their tuning or will it adjust automatically? Quote Link to comment Share on other sites More sharing options...
GT500R Posted March 29, 2016 Report Share Posted March 29, 2016 1. Not once 2. New tune with aggressive shift doesn't occur (check out my youtube video -> )3. They didn't adjust mine, but who knows how much they really would adjust just for a filter. 2 Quote Link to comment Share on other sites More sharing options...
bmwta Posted March 29, 2016 Author Report Share Posted March 29, 2016 Thanks for the reply and video. Quote Link to comment Share on other sites More sharing options...
luminator Posted March 29, 2016 Report Share Posted March 29, 2016 (edited) The filter will not change much as it is still the same piping it is pulling air through and that would be the limiting factor and a CAI is not needed unless you are planning to swap turbos and crank the boost up but then you will need more than a of the shelf tune. Edited March 29, 2016 by luminator Quote Link to comment Share on other sites More sharing options...
bmwta Posted March 30, 2016 Author Report Share Posted March 30, 2016 Thanks for the info Quote Link to comment Share on other sites More sharing options...
Joeracer321 Posted May 12, 2016 Report Share Posted May 12, 2016 How are the tuned edge sports holding up? Any issues showing up? How is drivability compared to stock? Lastly had anyone tried the jms boostmax add opposed to the tune? Quote Link to comment Share on other sites More sharing options...
037 Posted May 13, 2016 Report Share Posted May 13, 2016 Reporting in, Livernois tune did not break my vehicle just yet. No negative impact anywhere apart from the desire to race it and make other cars look bad. Here's a Vette Quote Link to comment Share on other sites More sharing options...
Joeracer321 Posted May 14, 2016 Report Share Posted May 14, 2016 How is the throttle response with the tune? To me it feels a bit lazy stock. Curious if the JMS pedal max would help if it still feels lazy from a dig. Quote Link to comment Share on other sites More sharing options...
037 Posted May 14, 2016 Report Share Posted May 14, 2016 Throttle response is good especially in Sport mode as it seems it keeps tranny operating in 5 gears so it's always 1 gear lower than normal, lots of power all the time. End result is 15mpg but I prefer to count the smiles per gallon. Quote Link to comment Share on other sites More sharing options...
Joeracer321 Posted May 15, 2016 Report Share Posted May 15, 2016 Another question I have is that if an updated pcm firmware update is rolled out, will livernois apply the factory patch and send out updated tunes? This concern is what is drawing my attention to the JMS Boostmax product. It doesn't make the same power, but will maintain compatibility for future software updates from Ford. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 15, 2016 Report Share Posted May 15, 2016 You should always revert to stock (tune/MAP sensor/etc) prior to a dealer visit, you never know when they will flash the PCM. So check the strategy code before and after. If the strategy code has changed, notify your tuner and they will send out (or provide access to on a server, as with Livernois) updated tunes (usually free). A tune is the proper way to address a modern vehicle's performance capabilities. 1 Quote Link to comment Share on other sites More sharing options...
037 Posted May 15, 2016 Report Share Posted May 15, 2016 Correct as per above, flash software to stock prior to taking to dealer, confirm codes did not change and flash it back once done. LMS does provide free tune updates. Quote Link to comment Share on other sites More sharing options...
cjh Posted May 16, 2016 Report Share Posted May 16, 2016 I've always wondered, how easy is it to install the tune? I'm an idiot and am afraid I'd mess something up. Can someone explain the process with the LMS tune? Quote Link to comment Share on other sites More sharing options...
037 Posted May 16, 2016 Report Share Posted May 16, 2016 Easy, actually. Comes with instructions but here are the basics. Buy the tuner, plug it into the car port under steering wheel, goes in only one way. Turn power on to car without starting engine and read the codes LMS requires. Send the codes in with the email telling them what tunes u want, 87, 91, 93, towing. Once tune is ready you install their software on your PC, connect tuner to PC with USB and hit update. Wait 10-15, disconnect when done, go back to car, plug it in, accessory power mode and 2-4 clicks to choose what tune you want installed and then u wait for it to finish. Fairly painless and you can try multiple level tunes if you so wish. Or you can call up LMS and have them hold your hand. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 16, 2016 Report Share Posted May 16, 2016 Good time to check battery voltage from the tuner's setup menu also. Although the '15s are too young to have weak batteries, best to check anyway when you are pulling the strategy code to send to LME. Also advise you to not update the tune late on Friday or the weekend, so you can have rapid support should you need it. People get excited (rightly so) to install as soon as they can ... If an upgraded MAP sensor is part of what you are installing, install only after the tune is uploaded to the Edge, and BEFORE you restart the engine. Not a big deal, but makes for a smoother experience. Quote Link to comment Share on other sites More sharing options...
always on edge Posted July 27, 2016 Report Share Posted July 27, 2016 1) Any issues with the "check engine" light coming on at any time? 2) Has the 3rd to 4th gear shift lag at full throttle improved over time? 3) If I wanted to add a K&N filter, would LMS need to know about it to adjust their tuning or will it adjust automatically? Yes. I had the check engine light come on when I started my truck this morning. Drove to work and then straight home, about 6 miles. I didn't notice any performance issues but I also didn't push it. When I got home, I pulled the codes - P0607 (Powertrain, computer and auxiliary output circuits, control module performance) and U3000 (Network communications, air/fuel metering, auxiliary emission control). I called Anthony at LMS and he said he's never heard of this. He recommended I flash back to stock and leave that way for a week or so and monitor for any codes on the stock tune. He said it could be a faulty PCM and although not a common problem, it happened on a friend's EB 3.5 F150. Quote Link to comment Share on other sites More sharing options...
tp16sport Posted October 25, 2016 Report Share Posted October 25, 2016 (edited) Probably a fairly obvious answer to an uninformed question... does the LMS blow the 70k/7yr warranty I bought? Assuming so, if I blow a gasket or (god forbid) tranny can I a) flash it back to stock while assuming engine warnings are at def con 1 and b ) can ford tell the chip has been flashed? 16 edge sport awd with basically all options @5k miles. Thanks! Edited October 25, 2016 by tp16sport Quote Link to comment Share on other sites More sharing options...
gjb89 Posted October 25, 2016 Report Share Posted October 25, 2016 From what I understand they have to have a hunch that you tuned it and have to look for it specifically. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 25, 2016 Report Share Posted October 25, 2016 Livernois works very closely with Ford, and I doubt they will put anything in a tune that would jeopardize the warranty. They will tell you the expected maintenance to go with the tune. IF they step outside these parameters, most certainly you will be signing some sort of release clause paperwork at the same time. They are a big shop and don't want their reputation tarnished. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted October 25, 2016 Report Share Posted October 25, 2016 If the tune contributed to the failure then that failure won't be covered but it doesn't void the warranty. And I believe they can tell if it was flashed even if you put it back to stock. That said I wouldn't expect a problem provided you use the correct fuel. Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted October 26, 2016 Report Share Posted October 26, 2016 Loving my tune! Have had the Edge for 3 weeks, Tuned for a week! Not that it wasn't fun stock, but the 93 Performance tune puts a smile on my face everytime I press the go fast pedal!! 2 Quote Link to comment Share on other sites More sharing options...
