Brake Lights
mcali6301
Can you post a pic of what's going on? This is in the taillight assembly, right, not the spoiler/3rd brake light assembly?
EDIT: These are the parts included in the taillight assembly -
Item Part Number Description
1 W712801 Rear lamp assembly bolts (2 required)
2 13404/ 13405 Rear lamp assembly (RH/LH)
3 13466 Park/ turn/ stop lamp bulb
4 13466 Lower inner rear lamp assembly bulb
5 13466 Upper inner rear lamp assembly bulb
6 13466 Park/ turn/ stop lamp bulb
7 — Rear lamp assembly socket and wire assembly (part of rear lamp assembly)
8 13A457 Lower rear lamp assembly grommet
9 13A457 Upper rear lamp assembly grommet
10 W711031 Rear lamp assembly nut (2 required)
Edited by WWWPerfA_ZN0W
The 2011-2015 Edge has 4 bulbs type 3157K. 2 on each side, 1 in the upper half & 1 in the lower half. The bulb is a dual filament type so 1 filament operates the parking lights & the other for the brakes. Most probably you have the brake filament burnt, hence only the tails/park lights are still working.
This explains the need for only 2 bulbs, thanks! I can do this myself.
