Back up sensors
How do you know the sensors are working, have you scanned them with a tool of some sort? Any incidents/issues involving the rear bumper?
If everything else checks out, you may need to replace the Parking Aid Module (PAM). Probably requires a trip to the dealer for configuration. Or ask Circuit Medics if they repair, and if the cost is worth it.
Removal and Installation
  1. NOTE: Module configuration is only required if a new Parking Aid Module (PAM) is being installed.
    Upload the PAM configuration to the scan tool. For additional information, refer to Programmable Module Installation (PMI) in Section 418-01 .
  1. Remove the LH rear quarter trim panel. For additional information, refer to Section 501-05 .
  1. Remove the 2 nuts and the PAM .
    • Disconnect the electrical connector.
  1. To install, reverse the removal procedure.
    • Download the configuration information to the PAM . For additional information, refer to Section 418-01 to carry out PMI .
