greeneye150 Posted March 5, 2016 Report Share Posted March 5, 2016 just got a new 2015 edge se 2.0 awd. its been years since i own a ford and i have noticed anything plugged into the accessory (lighter) socket, stays on after the car is turned off. are these power outlets always on or wil they turn off by themselves? thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted March 5, 2016 Report Share Posted March 5, 2016 They will stay powered on until the door is opened for sure. After that it seems to vary by model. Sometimes one port stays powered and one doesn't. Just test it by shutting off the vehicle and opening the door, then check the ports. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted March 5, 2016 Report Share Posted March 5, 2016 yeah most cars with multiple ports have one dedicated to staying "active" when the car is off Quote Link to comment Share on other sites More sharing options...
WingNut Posted March 5, 2016 Report Share Posted March 5, 2016 I don't think any of them stay active all the time. I believe they stay active for ~10 minutes and then they shut off. That is just my experience and I remember reading about it here. But since the new change in forum configuration, I am not going to even try to search for it. Quote Link to comment Share on other sites More sharing options...
greeneye150 Posted March 5, 2016 Author Report Share Posted March 5, 2016 thank you for the quick replies, i didnt want to do a trial and error on a new battery lol.....i also read they turn off in 10 minutes of inactivity Quote Link to comment Share on other sites More sharing options...
cab2g Posted March 22, 2016 Report Share Posted March 22, 2016 The USB ports stay powered when the car is off. That's for sure. Quote Link to comment Share on other sites More sharing options...
Bobs2015EdgeSport Posted March 23, 2016 Report Share Posted March 23, 2016 I ran into this very same perplexing problem, when I first got my 2015... that is, will they stay on or not? Here is what I determined: IF you're simply running a very low current draw item (like a cellphone charger adapter, or in my case, a dashcam), my outlets seem to stay "hot" for hours, even overnight. BUT, when I plug-in my magnetic revolving rooftop light (I do some fire dept. volunteer work), it was turned-off (by the car) within 10 seconds of turning-off the ignition. Obviously, while parked hazardously at a fire scene, that would never do... so, because I have a two-way radio that runs off of a heavy wire run directly from the car's battery, I disconnected the power port in the rear of the car and rewired it directly to my non-standard heavy battery lead in the rear. Now, that power port is "hot" all the time, being fed directly from the battery, so I can run my magnetic roof light (and anything else) for as long as I need to! 2 Quote Link to comment Share on other sites More sharing options...
cjh Posted March 23, 2016 Report Share Posted March 23, 2016 I've been trying to figure out how long they stay hot as well. I have a radar detector plugged in and it stays on for at least an hour after I turn the car off, but shuts off after maybe 3 hours? I've yet to pinpoint the duration of time yet. I'd prefer it shut off right away. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 23, 2016 Report Share Posted March 23, 2016 Are you sure the vehicle is shutting off power? Maybe the detector shuts itself off. Quote Link to comment Share on other sites More sharing options...
cjh Posted March 23, 2016 Report Share Posted March 23, 2016 Are you sure the vehicle is shutting off power? Maybe the detector shuts itself off. The detector has a feature that shuts itself off after 4 hours without the vehicle moving (9500ix with GPS), but power is cut to it sometime before then. I go into work at 9AM and usually go to lunch around 12PM and it's turned off by then. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 23, 2016 Report Share Posted March 23, 2016 The detector has a feature that shuts itself off after 4 hours without the vehicle moving (9500ix with GPS), but power is cut to it sometime before then. I go into work at 9AM and usually go to lunch around 12PM and it's turned off by then. Did we already have this conversation? Quote Link to comment Share on other sites More sharing options...
cjh Posted March 24, 2016 Report Share Posted March 24, 2016 Did we already have this conversation? I've only had the detector for four days, so no. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 24, 2016 Report Share Posted March 24, 2016 Wow. Severe case of déjà vu. Quote Link to comment Share on other sites More sharing options...
Bobs2015EdgeSport Posted March 24, 2016 Report Share Posted March 24, 2016 I have a dashcam that is hardwired directly into the forward power port, and, presumably because it draws almost nothing, the camera can usually stay on for hours after I shut off the car... although, occasionally, I will likewise hear it shut off (it beeps) sometimes as soon as I turn off the ignition. Go figure! Quote Link to comment Share on other sites More sharing options...
