07FordEdgeSELplus Posted February 29, 2016 Report Share Posted February 29, 2016 Ok so here it goes, sunroof worked perfectly fine, I changed out all the interior lights with LED. Looks fantastic. Ever since I have done that, the sunroof opens, slowly, starts to open, stops, opens more stops. Only opens halfway and then stops. What is going in here?? Quote Link to comment Share on other sites More sharing options...
cjh Posted February 29, 2016 Report Share Posted February 29, 2016 Maybe a blown fuse? I'd check there first. Quote Link to comment Share on other sites More sharing options...
07FordEdgeSELplus Posted February 29, 2016 Author Report Share Posted February 29, 2016 fuse is fine boss, i greased the tracks, im wondering if with the LED lights being a low resistance has something to do with the sunroof? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 1, 2016 Report Share Posted March 1, 2016 Doesn't seem to have a coralation between the two. Really sounds like a coincidence. Sounds silly, but if you feel that there is a connection, you could go back and try substituting the original incadescent bulbs, see if the window returns to normal. Are you certain that you got all of the lubrication in all the right places? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 1, 2016 Report Share Posted March 1, 2016 Looking over the circuit, I don't see any connection between lighting and roof opening panel. Agree probably not fuses, but did you check all three? Fuse #18 in battery junction box, #17 in fuse panel (global open) & #41 (delay acc.) Only one location where the roof panel and interior lighting are connected is at S903, a ground connection. This is under the headliner, directly over the drivers door. No possible way that installing LEDs could cause this IMO. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 2, 2016 Report Share Posted March 2, 2016 Do you know if the wiring/logic for the BAMR goes through the SJB also, enigma? Quote Link to comment Share on other sites More sharing options...
fit1446 Posted March 2, 2016 Report Share Posted March 2, 2016 (edited) On 2/29/2016 at 2:49 AM, 07FordEdgeSELplus said: Ok so here it goes, sunroof worked perfectly fine, I changed out all the interior lights with LED. Looks fantastic. Ever since I have done that, the sunroof opens, slowly, starts to open, stops, opens more stops. Only opens halfway and then stops. What is going in here?? o Edited March 3, 2016 by fit1446 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 2, 2016 Report Share Posted March 2, 2016 On 3/2/2016 at 1:05 AM, WWWPerfA_ZN0W said: Do you know if the wiring/logic for the BAMR goes through the SJB also, enigma? looks like main power comes off fuse 18 in the battery junction box. Secondary power is taken through 17 & 41 in the SJB. 17 is global open, & 41 is accessory delay. But main power, what you use when you hold the overhead switch, comes from the engine compartment fuse block. It appears that the logic is actually in the BAMR "smart front glass motor". I just can't see any connection between the substitution of LEDS and the BAMR motors. (I could be wrong, but it does appear that the lighting and moonroof motors are totally isolated). Dennis Quote Link to comment Share on other sites More sharing options...
