Steering controls!
Recently purchased a 2013 Ford Edge SEL. The volume control button on the steering wheel works intermittently. However the other controls on that side work perfectly without and issues. Could it be a bad connection on the volume part? Priced a new one at $32 so worse come to worse I can buy another one. Didn't know if anyone else has had this issue or any possible fixes! Thanks!
  • 5 months later...
Possibly the slip ring. You might be able to isolate by trying the volume while turning the steering wheel. (My thinking is there maybe a bad spot on the slip ring or bad contact touching the ring which would show up as an intermittent connection when turning the wheel).
Don't believe it's a ground as the ground is common between all the switches.
