2011 Edge - Odometer and backlight stays lit
smohr
Hi,
Our 2011 Edge started an intermittent problem. I turn the vehicle off, remove the key, get out and lock the vehicle... the odometer and backlight of the display stays on. I have to restart then turn off the vehicle and then the display turns off.
any thoughts
thanks
Steve
You are suffering from Windows Tech-knowledge I have things like that happen all the time. Ford has a better idea unfortunately you have to wait until they put Blackberry tech in which happen a couple of years later.
All you can do is either live with it, take it to the dealer to have your system rebooted at about $125.00 per session or pull the main fuse and then reset everything. After taking it to my dealer twice on warranty and having the same things happen two months later I just live with it. It will go away for a while then return in its own time.
