Shifting from R to D
mcali6301
This does not always happen but I've been noticing some slight delays when shifting from R to D. When I shift into D, sometimes it engages right away and sometimes I get a 2 second delay, which can be annoying because it causes a slip when I press the pedal.
Another funny thing I noticed is when backing out of spaces slowly, sometimes without the brake, I shift into D with no issue at all...I realize this may not be a good habit but I thought it was weird that using the brake can cause this delay sometimes but then NOT using the brake always seems to work flawlessly even while moving backward at 1-2mph..
