LED License Plate bulbs flickering
Hey All,
Has anyone purchased the LED puddle and license plate bulbs from drivebright.com? I had purchased the set not too long ago and the first set of license plate bulbs began to flicker. I contacted the company and they shipped me out new ones and those worked well for about 2 weeks or so and also began to flicker. Anyone run into any issues like this? It quite annoying to say the least haha. The puddle lights work fine with no issues. Thanks!
So i was finally able to get it fixed after the ones i kept receiving from drivebright ended up blowing out my middle light bar. After the dealership replaced my bar and installed new OEM bulbs, i ordered these error free LED license plate bulbs from Amazon and they did the trick. Have not had any issues with them so i'd be careful with buying them from drivebright.com. The puddle lights are good though.
  • 9 months later...
I've been having the same problem. Lights worked great for months then one day started to flicker. Drivebright sent a free replacement. They worked for a day or two then started to blink. If I pop the bulb out and put it back in it seems to temporarily fix the problem. I did notice the LED light gets very hot even after 15 min remote start. I was going to put a multimeter to the socket but glad know it's the blubs and not my car.
There's definitely something going on. LED's can get hot but they shouldn't be that hot, that quickly.
I don't remember the brand of mine (they were already installed in the used 2011 Edge that I bought) but I've noticed since a couple of weeks one of the license plate leb bulb was flickering/failing.
First thing I've done is to exchange the left/right bulbs to check if it's not the socket. It wasn't the case.
What I've actually found is I'm putting pressure on the LEDs themselves, they are lighting up again. It seems that over time, they are desoldering.
Hey All,
Had the same issue within a week had a single side flickering... I also turned to Amazon as others, I purchased the following
https://www.amazon.com/gp/product/B01E6Z2D04/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 Not only no flickers but very bright, looks great at night.
