Dash Light Sensor Cover
4 members have voted
  1. 1. Would you use a sensor cover so your lights are always on?
    • Yes
    • NO!
      3
There is a poll at the top of this Thread, submit your vote!
I 3D printed a cover for the light sensor on the dash. Why you ask? I have always been trained to turn my lights on when I drive, so I am constantly switching my lights from Auto to On. It is not that big of a task, but this just allows the car to automatically turn the lights on for me. The print below is the first print and isn't cleaned up perfectly. I just wanted to see if it would work, and it does!
Here are shots of the piece. I printed it in red ABS and painted it black. I do not have black filament at the moment.
Top:
Bottom:
Sensor without the cover on:
Sensor with the cover on:
Outside look of the cover on through the windshield:
The immediate drawback I can see is that the instrument cluster dims because it thinks it is night time. I am able to stop the auto-dimming function of the touchscreen so that I can see it better while daytime driving.
Does anyone know if there is a difference in the intensity of light between when your headlights are on during the day and night time?
Edited by Cellbine
On the 2011+, I believe the front turn signals are the OEM DRLs, but people many times want to use the vertical light bars instead. Some find the OEM light bars inadequate for this purpose, and install the DTBL product instead.
http://www.fordedgeforum.com/topic/12612-just-got-my-drl-activated-at-the-dealership/
http://www.fordedgeforum.com/topic/12919-ford-edge-vertical-led-daytime-running-lights-in-stock/
In older MYs, this is the OEM setup:
Daytime Running Lamps (DRL)
The DRL system operates the low beam headlamps at a reduced intensity.
The SJB supplies pulse width modulated (PWM) voltage to illuminate the low beam headlamps at a reduced intensity when the following conditions are met:
  • The ignition switch is in the RUN position.
  • The headlamps have not been turned on by the autolamp system or the headlamp switch.
  • The transmission is not in PARK (P).
As far as the 3D modeling, practice makes perfect!
Edited by WWWPerfA_ZN0W
