dxg Posted January 26, 2016 Report Share Posted January 26, 2016 Wondering if anyone knows how to take the instrument cluster apart. I got it out of the car, the lens pops off and so does the bezel assembly, but you're then left with the gauges and electronics in the housing and no obvious way to take it apart. Quote Link to comment Share on other sites More sharing options...
dxg Posted January 27, 2016 Author Report Share Posted January 27, 2016 Ok, got the answer talking to a speedo shop. You pop the needles off and then there are little collars under the needles that you carefully pry off. Then the plastic overlay comes out. For those wondering, no, there aren't any serviceable parts inside. One pcb with everything on it. The reason I took it apart is that the clear "window" of the overlay sheet doesn't line up properly with the alphanumeric display, so it looks very cheesy. I thought they may have been mis-assembled and I could adjust them a bit. In fact, there was no mis-assembly, very little slack and no room for adjustment. Apparently the misalignment is just part tolerances. In other words, poor quality. If you have this problem, don't bother. Just get another cluster. 1 Quote Link to comment Share on other sites More sharing options...
fit1446 Posted January 28, 2016 Report Share Posted January 28, 2016 What about changing the leds? Did u notice if they are actually green, or are they clear behind a colored overlay? Quote Link to comment Share on other sites More sharing options...
