Judy Mytty Posted January 26, 2016 Report Share Posted January 26, 2016 NEED TO KNOW WHY MY LOW OIL PRESSURE LIGHT IS ON WHEN I JUST GOT IT CHANGE AND SEE NO VISIBLE ISSUES Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 26, 2016 Report Share Posted January 26, 2016 Could be they did not put in enough oil or the right weight of oil. Has happened before. Also possible the filter or the oil drain plug was not tightened properly and there is a leak from that area. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 26, 2016 Report Share Posted January 26, 2016 It means the oil pressure is too low or the sensor is bad. Check the oil level immediately and don't drive it with the light on - you could damage the engine. It's entirely possible they didn't fill it back up. If it has oil and no visible link it's either a bad sensor or the oil pump or maybe the wrong filter - in any even it's not safe to drive with low oil pressure. Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 28, 2016 Report Share Posted January 28, 2016 If the light is on: Bad sensors. If sensors are changed and oil pump light still on worse case scenario is oil pumps most of the time do not fail. The reason for the low oil pressure may be an indication of something far more serious such as worn bearings causing the pressure to drop which means your engine has failed. A new pump will not help this situation. The easiest and cheapest way to see if your engine has damage and is failing is to sample your oil and have this analysis performed 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 28, 2016 Report Share Posted January 28, 2016 (edited) I've found that its not all that uncommon that the shop doesn't always completely fill the oil. When it takes 5-1/2 qts. I've seen them use only 5 qts. telling me that it's okay. First step, check your oil level. Edited January 28, 2016 by enigma-2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 29, 2016 Report Share Posted January 29, 2016 That is why you find a good shop that shows you the oil level when they are finished changing it. Then stick with them. On 1/28/2016 at 5:45 PM, enigma-2 said: I've found that its not all that uncommon that the shop doesn't always completely fill the oil. When it takes 5-1/2 qts. I've seen them use only 5 qts. telling me that it's okay.First step, check your oil level. 1 Quote Link to comment Share on other sites More sharing options...
