squeaky Posted January 14, 2016 Report Share Posted January 14, 2016 (edited) I bought myself a Christmas present and swapped my halogens for HIDs Ordered from www.daytimebrightlites.com Here are some pictures of the after: Edited January 14, 2016 by squeaky Quote Link to comment Share on other sites More sharing options...
squeaky Posted January 14, 2016 Author Report Share Posted January 14, 2016 (edited) And pictures of the install: Drivers side Bend down to hide away: Passenger side was tight Had to loosen and remove the reservoir to get enough room The only good ground I found was way down under the reservoir : To reach it needed some extensions Edited January 14, 2016 by squeaky Quote Link to comment Share on other sites More sharing options...
squeaky Posted January 14, 2016 Author Report Share Posted January 14, 2016 (edited) All done: Edited January 14, 2016 by squeaky 1 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 15, 2016 Report Share Posted January 15, 2016 I bought myself a Christmas present and swapped my halogens for HIDs Ordered from www.daytimebrightlites.com Here are some pictures of the after: I think that output shot is enough to go back to halogen. That is a crazy cutoff Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 15, 2016 Report Share Posted January 15, 2016 Nice documentation, Squeaky! Tho I have to agree with Nick on the cutoff issue ... Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 15, 2016 Report Share Posted January 15, 2016 I mean honestly I'm not even impressed with my OEM 15 Sport HIDs and will probably swap projectors later in it's life. your cutoff should have absolutely zero parts of it aiming up and the lowest parts should be on the drivers side.my cutoff Quote Link to comment Share on other sites More sharing options...
squeaky Posted January 15, 2016 Author Report Share Posted January 15, 2016 I wish I had a before shot of the factory halogens It did take some getting use to but after almost a month now I really like them Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 15, 2016 Report Share Posted January 15, 2016 Pretty sure oncoming traffic doesnt agree with you 1 Quote Link to comment Share on other sites More sharing options...
squeaky Posted January 20, 2016 Author Report Share Posted January 20, 2016 Pretty sure oncoming traffic doesnt agree with you Have yet to be flashed by anyone Quote Link to comment Share on other sites More sharing options...
remsleep Posted January 20, 2016 Report Share Posted January 20, 2016 I did exactly same kit 5000 l Look like 70 % driver has car with same light Nobody flashed when I am driving Quote Link to comment Share on other sites More sharing options...
andrewv28 Posted January 21, 2016 Report Share Posted January 21, 2016 Remsleep did your cutoff line look like squeaky's? I just ordered the same set and am hoping it will be more of a straight line Quote Link to comment Share on other sites More sharing options...
remsleep Posted January 21, 2016 Report Share Posted January 21, 2016 Almost same. I and my some did little ailment to place light more downi have 1,5 week and work fine My was add without harness it was backup order Now I have may add this week But work great I not remove nothing to install Worse passenger side My son can use his hand and place bulb easy Nice kit Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 21, 2016 Report Share Posted January 21, 2016 Remsleep did your cutoff line look like squeaky's? I just ordered the same set and am hoping it will be more of a straight line Only way to achieve that is with actual HID projectors Quote Link to comment Share on other sites More sharing options...
Rob Bonacic Posted January 31, 2016 Report Share Posted January 31, 2016 I installed HID kit on my titanium and my lights flicker when on and then turn off... the ones you bought have canbus? did you relay them from the battery? going back to the crap halogens for now.. Quote Link to comment Share on other sites More sharing options...
remsleep Posted January 31, 2016 Report Share Posted January 31, 2016 Yes I install first without harness Now I add harness Just short blink and work fine after start Quote Link to comment Share on other sites More sharing options...
Rob Bonacic Posted February 1, 2016 Report Share Posted February 1, 2016 (edited) remsleep, do your lights work when in Auto mode? i heard when utilizing a harness they don't work correctly when in AUTO mode Edited February 1, 2016 by Rob Bonacic Quote Link to comment Share on other sites More sharing options...
remsleep Posted February 1, 2016 Report Share Posted February 1, 2016 Yes exactly Quote Link to comment Share on other sites More sharing options...
remsleep Posted February 1, 2016 Report Share Posted February 1, 2016 It's not big deal I like brightness easy to my vision I can turn on in auto when darkness coming I afraid bulb will burn out too fast if light stay all time Any solution? Quote Link to comment Share on other sites More sharing options...
