Your new 2016 Edge review
  On 2/9/2016 at 12:31 PM, SweetCandyEdge said:
20" Touren TR60 rims with P245/50R20 Bridgestone Blizzak DM-V2 tires and Ford decals.
If you don't mind my asking, what width / offset / hub bore on the wheels? I'm thinking about getting a set for the new 2016 I just ordered?
Thanks!
Anton
Edited by Cougster
Thanks!
Anton
20" x 8.5", 40 mm offset, 72.62 mm hub bore
Hub centric rings are recommended and I believe the oem lug nuts are a tight fit with the center caps. I went with open ended lugs.
Edited by SweetCandyEdge
Hub centric rings are required and I believe the oem lug nuts are a tight fit with the center caps. I went with open ended lugs.
Hub centric rings are not required! Hubcentric wheels don't support load through the hub, all it does is help to better center the wheel to reduce the chance of vibrations. But tightening the lugs by hand in a star pattern is just as good.
  On 2/11/2016 at 7:22 AM, t0lkman said:
Why would you guys install 20"? doesn't it make your car more noisy and firm?
Aesthetics and performance. Noise from wheels is generally more from the tires due to road noise so a decent set of tires makes a big difference for noise. I find the DM-V2 to be very quiet compared to other winter tires. Larger wheels and tires are generally more expensive and tend to ride more harsh (depending on air pressure) but it's worth it IMO... after all, I did buy the Sport :D.
I picked up my sport on Friday, absolutely love it so far!!!!!!!!!!!! The only thing that is annoying is the 2 honks to alert the vehicle is running while key fob is in my pocket. My '11 didn't make this sound. This is truly annoying. I like to park the car the get coffee in morning and leave the car idle for while I run inside the store. But this alert is annoying. Give us an option to turn it off!! Prob won't happen lol. Other than this, the Sport is amazing!
Edited by Manny2525
@jmr061 has a mod to disable it on some newer Ford models at his website, http://www.fordpimods.com/double-horn-honk.html
Have a chat with him, he might be able to do it for the Edge.
Took delivery of my SEL January 27, totally dissapointed with the workmanship. After I drove it home, found a couple of major paint defects and broken sun visor clip. Trip back to the dealership, work order open and since been parked in the garage. Scheduled to go in tomorrow to the bodyshop for repairs. While prepping the car today, found another set of paint defects. Total to date is 14 paint defects. Pictures attached of the main ones:
A pillar-driver side
A pillar passenger side
Hood
Tailgate
Broken sun visor clip
Surprising how all of these defects passed quality assurance at the factory and pre-delivery inspection at the dealership.Makes me almost regret trading in my 2013 EDGE
Edited by ONEDGE16
For some reason mine stopped doing the horn honk when I leave it running. It is kind of annoying but it's a safety feature. Too many old people forgetting to turn off their cars while parked in the garage and dying from carbon monoxide poisoning.
Today I confirmed with Jason from fordpimods that his technique for disabling the double horn honk should work on the 2016 Edge. At least he confirmed it for my VIN. Now I just need someone or a local dealer willing to apply the change with Ford IDS. Anyone have access to Ford IDS in Ottawa area?
Hood
Tailgate
That sucks, is it 2016 model?
