Driving me nuts! Remote Starter
I'm sure you did, but did you try the troubleshooting guide on their website? I took a quick look and it has a section for "Ignition turns On, but never Starts/Cranks"
If the LED does not turn on, it has you look at this:
"There is a problem with the (-)while running signal. You may want to try grounding that wire (DARK BLUE on the EVO-RIDE) to see if the LED turns on. If it does, something is wrong from the RS end. If you are using Datalink make sure you remote starter is set to the Fortin Datalink protocol"
If LED works, then you may have programming issue and you need to update and reprogram module
http://fortin.ca/en/support/troubleshooting.html
