Mute Button On Steering Wheel Inoperative-Non-Sync Equipped Vehicles TSB 14-0172
TSB 14-0172 MUTE BUTTON ON STEERING WHEEL INOPERATIVE – NON-SYNC EQUIPPED VEHICLES.PDF
Publication Date: September 15, 2014
FORD: 2014 Edge, Taurus
ISSUE:
Some 2014 Taurus vehicles built on 2/4/2014 and through 2/25/2014 and 2014 Edge vehicles built on 11/18/2013 and through 2/25/2014 may exhibit an inoperative steering wheel mounted mute button. This is only observed on non-Sync vehicles.
ACTION:
Reprogram the front controls display interface module (FCDIM) to the latest calibration using IDS release 91.05 and higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com.
OPERATION DESCRIPTION TIME
140172A 2014 Taurus And Edge: Reprogram The FCDIM And Clear Codes (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
18B955 (Taurus) 42
19C116 (Edge) 42
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
•Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
•Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
