100 Series Remote Start, Engine Starts then Stops
I installed the OEM Ford 100 series remote start a few months ago when i bought my 2011 Edge. Worked flawlessly up until yesterday. Now everytime I start the Edge it's starts runs for a few seconds to 30ish seconds or so then stops. No warnings on the car, no lights, nothing. The only thing I can think of in my research is low battery voltage but I checked that and it's holding 12.25v (a little low, but still good) after sitting overnight, and the truck still starts normally with the key, and remote but shuts off on its own with the remote.
Anyone got any ideas on this one?
Thanks
Edited by James Smith
I think you are on the right track with checking the car battery. Have it tested for CCAs with a modern, digital load tester. Also check the wiring for the system, see if any cables are shorting or contacts/connectors show corrosion/contamination.
Remote starts usually have a runtime that is either fixed or user-programmable. If it is user-programmable with this kit, see if you can change the delay timer and it sticks.
I tried multiple changes within the system itself, changed the run times, disabled it, turned it back on, turned off the auto climate, just about everything in the menu has been toggled. And no changes in how it operates.
I'll go get the battery tested tomorrow, it is the original battery and might not be a bad idea to replace it anyways.
The CCA's on the old battery were low, only putting out 382 of the rated 540, Replaced the battery, and I THINK that might have taken care of it. Since then it has only shut off once and every other time it had stayed running. Time will tell if I have to investigate something else as the cause of the issue.
Well, it looks like the issue wasn't the battery, over the last week its been about a 50/50 chance of the Edge turning itself off. I'm starting to think it might be the cold weather causing issues as when it turns off it is below freezing (go figure) I might try a new hood pin as that is exposed to the elements the most. and it's a cheap part to try and diagnose an issue, thoughts?
You have to remember that as temperatures drop, so do the CCA's. The CCA rating is for 32F. So, if the temps are below that, and the CCA's are already low, you WILL have the problem. I stand by the battery replacement idea, personally. But sure, you can try replacing the hood pin, or just cleaning it up with a wire brush or #0000 steel wool pad if necessary. Might have some rust/corrosion that is creating extra resistance in the circuit. Coat with dielectric grease before reinstalling.
The Battery was replaced, terminals are as clean as could be. I'm targeting the hood pin because it is exposed to the elements, thinking that some water got into it to cause issues.
