nc3632 Posted December 31, 2015 Report Share Posted December 31, 2015 I was trying to get the air filter of my Ford Edge 2012 replaced. The Motorcraft FA-1884 is the recommended one by the owner's manual, however its rubber edge seems a little too thick -- I was having a hard time to putt the air box cover back on. Is it just a defected air filter? Or is this a common problem? Anybody got experience and could shed light on it? Thanks very much Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 31, 2015 Report Share Posted December 31, 2015 If it's just a little too thick, try trimming the edges with a razor or boxcutter etc. Should work fine afterwards. Quote Link to comment Share on other sites More sharing options...
nc3632 Posted December 31, 2015 Author Report Share Posted December 31, 2015 Thanks! I thought that since FA-1884 was the recommended one, it should have fit properly and I must have done something incorrectly. But let me try cut it thinner and give it a try. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 1, 2016 Report Share Posted January 1, 2016 Compare the thickness to the old filter. It's the first time I read about someone complaining of its thickness. I know that installing the filter is a little bit difficult, make sure the tabs are in all the way before pressing the cover down. There should be force/pressure required when putting the clips back, otherwise how would it seal? 2 Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted January 1, 2016 Report Share Posted January 1, 2016 Get a K&N Replacement filter and never change it again ! Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 9, 2016 Report Share Posted January 9, 2016 Make sure it is seated. Then look down to the right side and see the plastic tabs. Lift the left side up so that it is like a clam shell then push hard to insert the tabs into the slots. once all the way in then push down on the left side (no matter how much she complains) then once down clamp the two metal spring clamps into place and the spring clamps will take some effort. Result.....Next time will be much easier and enjoyable. The rest of you just have dirty minds.......LOL 1 Quote Link to comment Share on other sites More sharing options...
nc3632 Posted January 9, 2016 Author Report Share Posted January 9, 2016 Make sure it is seated. Then look down to the right side and see the plastic tabs. Lift the left side up so that it is like a clam shell then push hard to insert the tabs into the slots. once all the way in then push down on the left side (no matter how much she complains) then once down clamp the two metal spring clamps into place and the spring clamps will take some effort. Result.....Next time will be much easier and enjoyable. The rest of you just have dirty minds.......LOL Thanks macbwt! That was what I did. But at the last step, clamping the metal spring into place, I was not able to make it. I felt like I was giving it too much pressure and was afraid to break them. I'll give it another try since this is the right way. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 10, 2016 Report Share Posted January 10, 2016 If you have a rubber mallet, you can use that to help you. Or you can brace your palms along the top of the filter box while you pull up on the clamps, while reaching over the left fender. It's harder trying it while standing in front of the vehicle. I too did not realize how much effort it was first time around and earned a couple of painful reminders Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 12, 2016 Report Share Posted January 12, 2016 Just curious, did you put the old one next to the new one on a flat surface and compare what differences exist? Be interesting to see if they were made differently, or if the existing one became compressed. Quote Link to comment Share on other sites More sharing options...
nc3632 Posted January 13, 2016 Author Report Share Posted January 13, 2016 Just curious, did you put the old one next to the new one on a flat surface and compare what differences exist? Be interesting to see if they were made differently, or if the existing one became compressed. The materials being used are kind of different -- Old one is more firm and the new one is soft. Also the new one is obviously thicker than the old one. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 13, 2016 Report Share Posted January 13, 2016 May have to switch to aftermarket. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 13, 2016 Report Share Posted January 13, 2016 BTW, are you certain the old filter was Motorcraft and not an aftermarket? Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 13, 2016 Report Share Posted January 13, 2016 This is a video of me installing a brand new AEM dry air filter. I know I made it look easy, Trust me I cut out all of the video of me arguing with it. LOL 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 13, 2016 Report Share Posted January 13, 2016 You cut out the juicy parts, mac? Go figure! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 14, 2016 Report Share Posted January 14, 2016 You cut out the juicy parts, mac? Go figure!They're on the out takes reel. 1 Quote Link to comment Share on other sites More sharing options...
nc3632 Posted January 14, 2016 Author Report Share Posted January 14, 2016 BTW, are you certain the old filter was Motorcraft and not an aftermarket? It should be as I bought this vehicle brandnew Quote Link to comment Share on other sites More sharing options...
nc3632 Posted January 14, 2016 Author Report Share Posted January 14, 2016 This is a video of me installing a brand new AEM dry air filter. I know I made it look easy, Trust me I cut out all of the video of me arguing with it. LOL Hmm... I guess the part that you cut out is what I want to see. ;-) Quote Link to comment Share on other sites More sharing options...
akirby Posted January 14, 2016 Report Share Posted January 14, 2016 You must have picked up at least 10-15 mpg with that swap........ 1 Quote Link to comment Share on other sites More sharing options...
kkreit01 Posted January 30, 2016 Report Share Posted January 30, 2016 (edited) I have the same AEM that mac has. It was a somewhat of a tight fit, but it's supposed to be. I didn't have too struggle much. Edited January 30, 2016 by kkreit01 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 30, 2016 Report Share Posted January 30, 2016 It should be as I bought this vehicle brand newYou bought your Edge new in 2012 and this was the first time you changed the air filter? Ah, that's the problem, you waited too long, your air cleaner housing probably shrunk. 1 Quote Link to comment Share on other sites More sharing options...
