predapio Posted December 27, 2015 Report Share Posted December 27, 2015 Just got the missus another Edge. I had installed a Morimoto KID kit in her '13. Seems I cannot install this kit into the '15 because the low beams and high beams are different bulbs. The '13 had one bulb with the shutter for low/high beam. Am I correct that this kit cannot be installed? eff me, if so. Quote Link to comment Share on other sites More sharing options...
predapio Posted December 27, 2015 Author Report Share Posted December 27, 2015 As an addition to the above query. Does anyone know anything about an LED conversion kit? Would I need one bulb per side, or two? (one low and one high) Would it work? Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted December 28, 2015 Report Share Posted December 28, 2015 I was attracted here because of "retrofit" but I see you're not retrofitting anything, just adding a PNP Kit. PNP LED is not up to the same level as PNP HID currently. LED really needs proper projectors retrofitted to work at it's best. Quote Link to comment Share on other sites More sharing options...
dave80 Posted December 29, 2015 Report Share Posted December 29, 2015 Just some pics showing you what a good quality hid kit looks like installed on a 2015 edge. Quote Link to comment Share on other sites More sharing options...
predapio Posted December 29, 2015 Author Report Share Posted December 29, 2015 Just some pics showing you what a good quality hid kit looks like installed on a 2015 edge. Looks good, did you just use the low beam projector for the HID? Quote Link to comment Share on other sites More sharing options...
dave80 Posted December 29, 2015 Report Share Posted December 29, 2015 For now just using the stock projector. Quote Link to comment Share on other sites More sharing options...
predapio Posted December 29, 2015 Author Report Share Posted December 29, 2015 For now just using the stock projector. Thanks for the reply, here's what I'm having an issue with. I have the Morimoto system left from the '13 Edge. That Edge had the shutter to cut off the high beam (low and high were the same bulb). In this '15 Edge, if I install the HID into the projector, won't I be blinding others, since it's in effect a high beam bulb, without the shutter to make it low beam? Thanks for your replies. Quote Link to comment Share on other sites More sharing options...
dave80 Posted December 29, 2015 Report Share Posted December 29, 2015 You will need a new bulb. Different kind on 15's, and our high beam is seperate from the low beam. 1 Quote Link to comment Share on other sites More sharing options...
fit1446 Posted December 30, 2015 Report Share Posted December 30, 2015 yes you will need two bulbs for each side.but one plus is you can get two different heat levels if you want. 1 Quote Link to comment Share on other sites More sharing options...
predapio Posted December 31, 2015 Author Report Share Posted December 31, 2015 yes you will need two bulbs for each side.but one plus is you can get two different heat levels if you want. I'm kinda leery about putting an HID in a halogen's place, glare and such. Wonder how it'll look if I just use the low side for the HID 1 Quote Link to comment Share on other sites More sharing options...
fit1446 Posted December 31, 2015 Report Share Posted December 31, 2015 I'm kinda leery about putting an HID in a halogen's place, glare and such. Wonder how it'll look if I just use the low side for the HID i have hid for both low and high beams...i am a few years behind you as far as model year but i love the hid..i know my fixtures are reflective and made for halogen bulb,but i set my headlight angle immediately after install and i have never had anyone flash me as if they were bothered. they are much better than the halogen.but dont bother changing the high beam if you are contemplating it. you will get more light staying with halogen. just do the hid low beam and get some nice halogens for high. there literally is no difference in the amount of light i get from high or low..only difference is the high beam projects a bit more in width but honestly cant even notice...i have a different heat level for my high beams. i think as far as your fixture being reflective would affect an led bulb motre so than hid. but i could def be wrong.. 1 Quote Link to comment Share on other sites More sharing options...
andrewv28 Posted January 4, 2016 Report Share Posted January 4, 2016 Dave80, what hid kit did you go with? Quote Link to comment Share on other sites More sharing options...
s4tom3 Posted January 11, 2016 Report Share Posted January 11, 2016 http://www.fordedgeforum.com/topic/18411-hid-conversionfinally-i-can-see/ Quote Link to comment Share on other sites More sharing options...
