2007 rear differential removal
allport
Both rear axle seals are bad in my rear end and need to be replaced. I took a look and it looks like there is nt enough roo. To pull axles out of the diff without removing the axles and thus the rear suspension...
Is there a chance I can drop the diff I stead? Currently the drive shaft is out for a different reason and was wondering if this was possible.
Any tips for replacing these or dropping the diff would be helpful.
