WWWPerfA_ZN0W Posted December 20, 2015 Report Share Posted December 20, 2015 Fuel Pump – 2014-2015 Ford & LincolnNHTSA 15V005SUMMARY:Ford Motor Company (Ford) notified the agency on January 8, 2015, that they are recalling certain model year 2014 Ford Escape vehicles manufactured April 15, 2014, to May 8, 2014, and 2015 Lincoln MKC vehicles manufactured April 21, 2014, to May 15, 2014. On April 30, 2015, Ford expanded the recall to cover an additional 45,505 vehicles, including certain model year 2014-2015 Ford Transit Connect vehicles manufactured November 11, 2013, to August 29, 2014, 2014-2015 Ford Fiesta vehicles manufactured April 10, 2014, to June 17, 2014 and 2014 Ford Edge vehicles manufactured April 30, 2014, to May 21, 2014. Improper nickel plating of components within the fuel pump may result in the fuel pump failing.CONSEQUENCE:If the fuel pump fails, the vehicle may stall without warning, increasing the risk of a crash.REMEDY:Ford will notify owners, and dealers will replace the fuel pump, free of charge. The recall began on February 27, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford’s number for this recall is 14S30.NOTES:Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.REASON FOR THIS SAFETY RECALLIn some of the affected vehicles, the fuel pump may have been manufactured incorrectly, leading to increased susceptibility to mechanical pump seizure accompanied by a loss of fuel pressure. This may result in a no start condition, or an engine stall without warning or the ability to restart the vehicle. An engine stall without warning while driving increases the risk of a crash.AFFECTED VEHICLESVehicle Model Year Assembly Plant Engine Build DatesFiesta 2014-2015 Cuatitlan 1.6L (except ST) TBD Focus 2014 Michigan 2.0L (except ST) TBD Transit Connect 2014 Valencia 2.5L TBD Edge 2014 Oakville 2.0L TBD Escape 2014 Louisville 1.6L, 2.0L, 2.5L TBD AFFECTED VEHICLESVehicle Model Year Assembly Plant Option Build DatesEscape 2014 Louisville 1.6L, 2.0L, and 2.5L Engines April 15, 2014 through May 8, 2014MKC 2015 Louisville 2.0L Engines April 21, 2014 through May 15, 2014PARTS REQUIREMENTS / ORDERING INFORMATIONPart Number Description QuantityFuel pump and sender units (order one per vehicle) D2BZ-9H307-C Fuel pump and sender unit – Fiesta 1BV6Z-9H307-U Fuel pump and sender unit – Focus (unleaded fuel only) 1BV6Z-9H307-T Fuel pump and sender unit – Focus (flex fuel only) 1DV6Z-9H307-F Fuel pump and sender unit – Transit Connect 1DT4Z-9H307-B Fuel pump and sender unit – Edge 1CV6Z-9H307-K Fuel pump and sender unit – Escape (1.6L and 2.0L only) 1Additional parts needed to complete the repair (order all that apply) 4L3Z-9276-AA Fuel pump and sender unit seal (all vehicles) 1W700222-S442 Fuel tank strap bolts (Fiesta, Transit Connect, Escape) 1W710544-S442 Fuel tank strap bolts (Focus) 1N811781-S439 Fuel tank strap bolts (Edge) 1CV6Z-9450-C Exhaust gasket (Transit Connect) 1CV6Z-9450-D Exhaust gasket (Escape) 1W520103-S403 Exhaust nut (Escape) 15F9Z-4682-AA Driveshaft bolts (Escape AWD only) 3PARTS REQUIREMENTS / ORDERING INFORMATIONPart Number Description QuantityCV6Z-9H307-H Fuel pump and sender unit (1.6L and 2.0L only) 1CV6Z-9H307-J Fuel pump and sender unit (2.5L only) 14L3Z-9276-AA Fuel pump to fuel tank o-ring 1W700222-S442 Fuel tank strap bolts (4 bolts per package) 4 boltsCV6Z-9450-D Exhaust gasket 1W520103-S403 Exhaust nuts (4 nuts per package) 2 nuts5F9Z-4682-AA Driveshaft bolts (AWD only) 3 packagesOVERVIEWIn some of the affected vehicles, the fuel pump may have been manufactured incorrectly, leading to increased susceptibility to mechanical pump seizure accompanied by a loss of fuel pressure. This may result in a no start condition, or an engine stall without warning or the ability to restart the vehicle. An engine stall without warning while driving increases the risk of a crash. Dealers are to replace the fuel pump and sender unit.SERVICE PROCEDURE1. Replace the fuel pump and sender unit. Improper Plating on Fuel Pump may Result in Stall RCONL-15V005-9486 Owner Notification Letter(Part 577).pdf Improper Plating on Fuel Pump may Result in Stall RIONL-15V005-3523 ISSUED Interim Owner Notification Letter(Part 577).pdf Improper Plating on Fuel Pump may Result in Stall RCMN-15V005-7153 Manufacturer Notices(to Dealers,etc).pdf Improper Plating on Fuel Pump may Result in Stall RCMN-15V005-8353 Manufacturer Notices(to Dealers,etc).pdf Improper Plating on Fuel Pump may Result in Stall RCMN-15V005-8280 Manufacturer Notices(to Dealers,etc) - Advance Notice - Safety Recall 15S13.pdf Improper Plating on Fuel Pump may Result in Stall RCLRPT-15V005-5289 Recall 573 Report-Amendment 1.PDF Quote Link to comment Share on other sites More sharing options...
tamugrad2013 Posted December 24, 2015 Report Share Posted December 24, 2015 You know i have a 2012 Ecoboost and the fuel pump failed. Luckily it was under warranty, and don't have to dig up paperwork, I wonder if more than just 2014's are really affected. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 10, 2020 Author Report Share Posted October 10, 2020 @tamugrad2013 there is actually a memo regarding defective fuel pumps NOT needing a recall, associated with this issue. VERY strange. Recall 13S13_2012-13 Edge 2L-EB fuel line pulse damper metal housing may crack_ReplaceFuelLine_Memo-FPs not needing recall.pdf Quote Link to comment Share on other sites More sharing options...
