Whistle Noise from Mirrors at Highway Speeds – 2015 Lincoln MKC
WIND OR WHISTLE NOISE FROM EXTERIOR MIRROR(S) AT HIGHWAY SPEED – BUILT ON OR BEFORE 5/18/2015
LINCOLN: 2015 MKC
2015 MKC vehicles built on or before 5/18/2015 can exhibit a wind or whistle noise from the exterior mirror(s) at highway speed.
Follow the Service Procedure.
SERVICE PROCEDURE
Follow the procedure for the affected side(s).
  1. Position the exterior mirror glass for access. (Figure 1)
  2. Release the mirror glass and disconnect the electrical connectors. Use of a non-marring plastic trim tool is recommended to release the mirror glass. (Figure 2)
  3. Remove the two (2) screws and the mirror glass bezel. It is not necessary to remove the mirror motor. (Figure 3)
  4. Remove the screw and position the mirror cover aside. (Figure 4)
  5. Disconnect the two (2) electrical connectors.
  6. Clean the location shown in the figure with Isopropyl Alcohol. (Figure 5)
  7. Dry the surface using a lint free cloth.
  8. Install foam seal tape. (Figure 6)
  9. To reassemble, reverse the disassembly procedure.
Obtain Locally
Part Description
Isopropyl Alcohol
PART NUMBER PART NAME
FJ7Z-17724-A Foam Seal Tape (1 Per Mirror)
