WWWPerfA_ZN0W Posted December 20, 2015 Report Share Posted December 20, 2015 (edited) IDLE DIP AND/OR LOSS OF RPM ON DECELERATION OR WHEN COMING TO A STOP – 2015 Ford Edge 3.5L ENGINE – INTERMITTENT IDLE DIP AND/OR LOSS OF RPM ON DECELERATION OR WHEN COMING TO A STOP WITH NO DTCS PRESENT – BUILT ON OR BEFORE 7/28/2015 FORD: 2015 Edge Issue 2015 Edge vehicles equipped with a 3.5L engine and built on or before 7/28/2015 can exhibit an intermittent idle dip and/or loss of RPM on deceleration or when coming to a stop with no diagnostic trouble codes (DTCs) present. ActionReprogram the powertrain control module (PCM) to the latest calibration using release 96.04 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE’S COMPUTER TO LEARN THE TRANSMISSION’S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS. Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for: •Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present •Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported) In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application. J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules. www.motorcraftservice.com Edited December 20, 2015 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
