Jsenske Posted December 18, 2015 Author Report Share Posted December 18, 2015 Yeah. The outer part is actually broke so it probably is my cause seeing this would affect shift to 4th. There is stuff spinning when diode should have it stopped from that direction. Hopefully it all works out. I should have taken a picture but forgot 1 Quote Link to comment Share on other sites More sharing options...
Jsenske Posted December 20, 2015 Author Report Share Posted December 20, 2015 What is the reason you can't mix mercron v with Mercron lv. Just wondering the differences in transmissions that I belief are the same from 2008 to 2009 but the 2009 takes mercron Lv. Why can't mine use mercron lv Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 20, 2015 Report Share Posted December 20, 2015 Mercon LV is a thinner fluid than Mercon V, designed to improve fuel economy. Here are the comparative datasheets: Product Data Sheet MERCON V.pdf Product Data Sheet MERCON LV.pdf As you can see, LV has lower viscosity at all rated temperatures. Surprisingly, it shears more easily as well, with a lower VI than the V fluid. Beyond that, I don't have a clue what the differences could be. I am sure there are differences in the stabilizers and other additives as well. Mercon V MSDS.pdf Mercon LV MSDS.pdf Quote Link to comment Share on other sites More sharing options...
Jsenske Posted December 31, 2015 Author Report Share Posted December 31, 2015 Fixed the transmission. The root cause was bad TCM/solenoid pack. I'm sure the hard parts broke because of the strain the delayed shifting put on it. Wanted to make sure I posted the fix. Seems like a lot of people don't and you never figure out what people had wrong. 1 Quote Link to comment Share on other sites More sharing options...
Jsenske Posted January 2, 2016 Author Report Share Posted January 2, 2016 Anybody know the part # and the cheapest place you can get a solenoid assembly for transmission on a 2008 Ford Edge. The one I got is just to troubleshoot now I need to buy one Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 2, 2016 Report Share Posted January 2, 2016 (edited) Ask Benny at Levittown Ford Super Center for a quote. There's always EBay or other Ford dealers as a fallback, but I'd stick with Benny if it comes down to it. Solenoid Body Assembly - You will need: Module Assy - ECU - Callout Name: 7Z369 7T4Z-7Z369-E Module - Transmission Control (Tcm) Replaced by: AA5Z-7Z369-B 6-Speed Automatic Gasket - Callout Name: 7H200 7T4Z-7H200-A Gasket 6-Speed Automatic and Seal — solenoid body electrical connector partial part number 7J213 Edited January 2, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Brucifer Posted February 5, 2016 Report Share Posted February 5, 2016 Jsenke, Is the car back on the road or are you still waiting on parts? Quote Link to comment Share on other sites More sharing options...
