pwgsx Posted December 10, 2015 Report Share Posted December 10, 2015 Has anyone installed one of these units on a Ford Edge? https://fortin.ca/ I am only going to use it for the remote start feature. I found it while looking online to add remote start to my wife's car using the factory key fob. It seemed simple enough but it just arrived today and I am over my head I think. Yes the T harness part looks easy but nowhere does the guy show where these other random wires go coming off the harness. They are just bundled up but clearly some are hooked up. He then mentions tapping into the Can H and Can L but then the video just skips over that. HELP https://www.youtube.com/watch?v=I3csMxsq-S0 Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 10, 2015 Report Share Posted December 10, 2015 I did this in my 2012 edge it took maybe a half hour it works great call his tech support he was very helpful you don't have to splice any wires he gave you plastic clamps for the wires Quote Link to comment Share on other sites More sharing options...
pwgsx Posted December 10, 2015 Author Report Share Posted December 10, 2015 I contacted them and they were sorta helpful. He said I need to tap into the driver door pin wire- but the diagram shows to cut this wire. He said to also connect the rest of the wires on the T harness to the 20 pin wires. I also re flashed the unit to the most recent update but not its asking if the Edge comes with a factory alarm? Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 11, 2015 Report Share Posted December 11, 2015 I just connected the t harness like the video shows then I used those two plastic clips for the can h and can l wires then programmed it like the video shows did you get two plastic clamps I think they were pink Quote Link to comment Share on other sites More sharing options...
pwgsx Posted January 18, 2016 Author Report Share Posted January 18, 2016 Well I connected the t harness and can h and l but the keys wont program. I tried a few times, even watching this video I found on you tube and no luck. I dont get what is going on with this dam thing. Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted January 18, 2016 Report Share Posted January 18, 2016 My can wires were marked wrong from the factory call tech support and ask him if that's why you can't program it that was my problem I didn't splice any wires on mine Quote Link to comment Share on other sites More sharing options...
pwgsx Posted February 25, 2016 Author Report Share Posted February 25, 2016 So I ended up sending the evo back after having no luck getting it to program myself. I also had a locksmith make a new key directly from the car with their laptop as tech support said maybe both my keys were identical copies of each other. Still didnt work.........FF to a few weeks ago when I brought my car to a custom car install shop. He installed a "unknown unit" in the car, and he cannot get his unit to program. As soon as he installs the 2nd key the unit acts like there is no new key in the ignition and wont program. I left totally pissed off.....I began calling Ford dealers around the area and 2 had no clue what I was talking about and said there is nothing to "unlock" in the computer system in the car. The other dealer wanted $250 to hook up but claimed he really didnt know he could unlock anything as far as key programming. In my last effort, I asked my friend who works for Honda if he had any contacts to a Ford dealer. He called around and he basically got the same info- there is nothing to "unlock in the ford system" and they never encountered this issue before. Help before I pull all my hair out !!!! Quote Link to comment Share on other sites More sharing options...
