Austin Lutz Posted December 10, 2015 Report Share Posted December 10, 2015 I just purchased a used 2013 Ford Edge on October 31st 2015 and it has 36000 which I thought would be a great vehicle. Needless to say it has been a headache since the first week I got it. I started it up one day and the check engine light came on so I drove it in to the dealer and they replaced the fuel line and said that should do it. I had it back for 2 days and check engine light came back on with a strong gas smell so I took it back into the dealer and they replaced the purge canister valve and I drove it a couple days and still noticed the strong gas smell and I thought maybe if I park it in my garage and keep the windows open all night that would help so the next day I drove it and stopping and going at the stop lights the strong smell came back so I took it back into the dealer and they replaced the 4 vent at the rear of the car because they thought maybe the exhaust fumes was coming back into the cabin. I've had it back a couple of days and still the strong gasoline smell. I have no idea what to do with it, I just wish I could return the vehicle and get my chevy cruze back but it doesn't work that way. Any ideas would be much appreciated. Also there is no gas leaks under the car Quote Link to comment Share on other sites More sharing options...
akirby Posted December 10, 2015 Report Share Posted December 10, 2015 The problem isn't the vehicle - it's the incompetent dealer who should have fixed it the first time. I would take it to a different dealer at this point. 1 Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted December 10, 2015 Author Report Share Posted December 10, 2015 That is what i'm about to do... The only reason i've been still messing around taking it back to the dealer is because they are fixing it at no charge. Also I should mention that I filled it up with gas last night and drove across the parking lot and ran into a store and left it running and when i came back the RPM was revving up to the 1 then would almost die out then rev up to the 1 agian, So i'm sure it is all connected with the gas smell Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 10, 2015 Report Share Posted December 10, 2015 If it really is a gas smell, there could be multiple reasons, including those supposedly addressed by the dealer (a Ford dealer I presume?). Not done yet is exhaust system checks to see if there are any leaks. How has the MPG been? Should be decent, accounting for 10% drop with winter fuel. Definitely go to another dealer and verify that the work was actually done. Unrelated, but is your Edge AWD or FWD? AWD's tend to have PTU sickness, which can cause PTU fluid to spew and make evil smells. Also check to see if your cabin air filter (glove compartment) is clean & functional. 1 Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted December 10, 2015 Author Report Share Posted December 10, 2015 Thank you fot your input. Mine is a front wheel drive and the MPG have stayed around 23 to 25 also I just bought a cabin air filter and when i went to put it in there was nothing at all but a screen type thing that i just removed and put the new filter in. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 13, 2015 Report Share Posted December 13, 2015 (edited) Had a simular problem on my 09 MKX. Took it to the dealer and it turned out to be a broken vacuum hose located on the back side of the engine. It took about three hours to replace as they had to pull battery tray and some other stuff. Edited December 13, 2015 by enigma-2 3 Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted December 15, 2015 Author Report Share Posted December 15, 2015 I haven't drove it enought since I got it back to see if the smell is still there, but if i have to take it back in I'll definatily tell them to check the vacuum hoses Thanks Quote Link to comment Share on other sites More sharing options...
macbwt Posted December 15, 2015 Report Share Posted December 15, 2015 Also check the seal to ensure it was installed properly back on top of the tank. If the seal has fallen down during installation you will get a gas smell inside. The seal that fits between the top of the fuel pump and the tank to be specific. 2 Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted December 18, 2015 Author Report Share Posted December 18, 2015 had to take it back in yesterday and they still have it as a type. This time there going to repair the management valve because it isn't closing all the way and letting the fuel vapors escape. This will be the forth attempt so crossing my fingers Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 18, 2015 Report Share Posted December 18, 2015 What exactly is a "management" valve? Quote Link to comment Share on other sites More sharing options...
akirby Posted December 18, 2015 Report Share Posted December 18, 2015 Purge valve I'm guessing. Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted December 19, 2015 Author Report Share Posted December 19, 2015 That is what the service manager texted me exact words were 'the issue is a sticking vapor management valve.' Also I had to call the dealership and ask how much longer my car will be and they said Tuesday because they had to order parts. So it will be a day short of a week without a car; they claim to have no available loaners at this time so i'm thankful to be driving my moms old Durango. They had to order a canister to the purge valve. Which they already replaced the purge valve so i'm assuming the canister goes with this. I will update when I receive my car next week. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 19, 2015 Report Share Posted December 19, 2015 Wonder if there was any damage to the underbody fuel/evap line shield that led to this need. Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted December 21, 2015 Author Report Share Posted December 21, 2015 Well it was probably a bad idea when I bought it after seeing on the auto check that is was is a multiple impact collision. So I hope it will get fixed right Quote Link to comment Share on other sites More sharing options...
Austin Lutz Posted January 10, 2016 Author Report Share Posted January 10, 2016 After 4 times of attempting to fix the problem, I'm confident that it is finally fixed. They put in a second purge valve and replaced the canister as well and I think that did it!! 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 10, 2016 Report Share Posted January 10, 2016 good to hear, hope for the best Quote Link to comment Share on other sites More sharing options...
