gloria's edge Posted December 9, 2015 Report Share Posted December 9, 2015 Fellow Edge Members, Just got the following Field Service Action from Ford..... You can call Ford at....1-866-436-7332 to see if you vehicle qualifies for this action. Through my call with Ford and understanding, Ford will evaluate your cooling system to determine if you need a cooling flush at no charge to you. FSA Title: COOLING SYSTEM CORROSION Field Service Action Number: 09M04 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 10, 2015 Report Share Posted December 10, 2015 part of a program for 2007-2009 Edge/MKX Vehicles: http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=182324 09M04-S1 Certain 2007 through 2009 model year Edge and MKX Vehicles - Cooling System Corrosion.pdf 2 Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 10, 2015 Author Report Share Posted December 10, 2015 part of a program for 2007-2009 Edge/MKX Vehicles: http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=182324 09M04-S1 Certain 2007 through 2009 model year Edge and MKX Vehicles - Cooling System Corrosion.pdf part of a program for 2007-2009 Edge/MKX Vehicles: http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=182324 09M04-S1 Certain 2007 through 2009 model year Edge and MKX Vehicles - Cooling System Corrosion.pdf Thanks for the research and posting with more details on this! Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 10, 2015 Author Report Share Posted December 10, 2015 Thanks for the research and posting with more details on this! I have an appointment with my local dealer to have this looked at Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 21, 2015 Report Share Posted December 21, 2015 I have an appointment with my local dealer to have this looked atDid the dealer find anything? Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 22, 2015 Author Report Share Posted December 22, 2015 Did the dealer find anything? Here is what I was told....unless your vehicle is experiencing any type of heat loss or lack of heat, this field action does not apply to you. The obvious best way to know is by turning the heat on in your car. If you have perfectly good heat coming out (that's the case with me), then there is no need to bring the car in under this field action. I was a bit disappointed since I noticed the antifreeze/coolant in my vehicle is very dark and probably could use a flush/change. Hoping to have had this done under this field action but, I'll have to have it done on my "dime". Best Regards, Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 23, 2015 Report Share Posted December 23, 2015 Same here, mine needs fluid change as well. Thanks for bringing this up. Quote Link to comment Share on other sites More sharing options...
OGL2008 Posted September 18, 2016 Report Share Posted September 18, 2016 If Antifreeze change is needed is it necessary to use the ford gold that came with the vehicle? I noticed on the bulletin that its replaced with ford green antifreeze. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 18, 2016 Report Share Posted September 18, 2016 You can upgrade to specialty green, BUT green and gold are NOT compatible. So you have to flush out the gold antifreeze completely prior to putting in any green antifreeze. 2 Quote Link to comment Share on other sites More sharing options...
OGL2008 Posted October 4, 2016 Report Share Posted October 4, 2016 Thanks for the reply. Pres-tone Antifreeze says that it is compatible with all OEM coolants can this be added to my cooling system or does it also have to flushed before adding it to my Edge. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 4, 2016 Report Share Posted October 4, 2016 Best to call them up to make sure, but I think it should be compatible/just fine. The only caveat being that usually they say the universal coolant won't change the color of the original antifreeze when used to top off. If you replace a quart or more (not sure exactly where that cutoff is), you will see the color change. That can be confusing for a service shop, if they don't know what happened. One reason to do a flush is to get existing coolant out, but also remove gunk builtup in the cooling system. And yes, the coolant does leave deposits behind as it degrades over time. If your degas bottle is clean/clear, then likely the inside of the cooling system is also good. Quote Link to comment Share on other sites More sharing options...
