rdavid100 Posted December 5, 2015 Report Share Posted December 5, 2015 are there 2 heater door actuators on this model.....I have good heat on passenger side and thru the rear compartment but no heat on drivers side thru the floor vent, the dash vent or the defrost vent...A/C works fine..... Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 5, 2015 Report Share Posted December 5, 2015 Do you have the electronic dual zone climate control? If so, sounds like the Climate Control Module is done for. But sure, could be actuators, and yes there are two on the electronic version. Quote Link to comment Share on other sites More sharing options...
rdavid100 Posted December 5, 2015 Author Report Share Posted December 5, 2015 No it is not ----DUAL Control----just temp control in the center of the dash.....I just got thru flushing the heater core ... the door controller for the main duct works....turns from cold to hot......HELP Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 7, 2015 Report Share Posted December 7, 2015 (edited) On a non-dual system, the blend door should affect both sides equally. As you state it's working properly, there is only one other thing that I can think of as the cause: the heater core is blocked on the drivers side. (Allows full airflow through the core, but no heat to pick up). As a test, consider operating the air conditioner and test whether both sides are equally cold. If they are, then it's probably the heater core (either inside the core or some material that got into the heater system and is blocking the airflow through that part of the airflow. To support this, I found a large amount of some type of sponge rubber pieces blocking my cabin filter. Had no idea how it got into system, but did find it after an oil change at local Ford dealer). (???) If the ac is also not working, it's not the heater core. Has to be a blocked air chamber. Don't think the door is two-piece, but whenever this comes up it's always the driver's side that's cold. Does anyone know if the heat door is in two pieces or if its all one piece? Edited December 7, 2015 by enigma-2 Quote Link to comment Share on other sites More sharing options...
