HappyHourSport Posted November 29, 2015 Report Share Posted November 29, 2015 http://www.fordedgeforum.com/topic/19317-new-build-2015-sport-stealth-jl-12-components-and-some-s/?do=findComment&comment=142340 I posted in the audio/nav section but wanted to ask a few things here. How do you remove door panels on the 2015's? I am getting ready to start and don't want to jack up my panels the first day. They are different than any guide I found on here. Any help? And other ?'s And so now for the questions and concerns I have. 1. I upgraded to the LC7i 6 channel because I was going to tap into the front and rear door outputs. But the more I look into the "Sony Premium" wiring it looks like the fronts have a separate line for the in door tweeter instead of tapping into the 6x8 using caps as cutoffs. I can only assume this means the 6x8 is getting Mid range Hz's and the tweeter is getting the highs, all the way from DSP. If that is the case, I don't want to tap into a limited frequency range for my pre amp wiring. Where is the DSP located? I have the actual 2015 edge wiring manual on the way, as I couldn't find a solid source for this year. I will be sure to share any info I come up with on this trip. 2. If I end up only taping into the rear doors (assuming they have a full range feed, suspect they have separate tweeters as well, hopefully piggybacked off mid), should I downgrade from the LC7i since I will lose any fading ability anyway? 3. How are you guys dealing with vibrations added by more power? I hooked up my box to my truck amp and was amazed at how much vibration I had coming from a $40K vehicle. The doors seem to be holding up to a lot right now so hopefully they wont be a problem, but that tail end all the way up to the mirror and dash vibrate like crazy. Going to have to get creative. I had even tried putting the sub on the deck, thinking I had made a horrible mistake by building the box onto the body, but "luckily" it was the same in a standard location. 4. Any suggestions on rear door speakers? Never seem to be a priority with me, as stock speakers sound pretty good amped up usually. 5. Tips and tricks? Hidden screws that will ruin my day when trying to take a panel off? How to stop your wife from killing you when she sees her interior ripped out? Number for a good attorney? Any thing good like that! Quote Link to comment Share on other sites More sharing options...
HappyHourSport Posted December 3, 2015 Author Report Share Posted December 3, 2015 Still waiting for info on interior panel removals. But if anyone needs it, here is the wiring for the 2015 Edge with Sony Premium wiring diagrams. http://imgur.com/a/Vz3rT 1 Quote Link to comment Share on other sites More sharing options...
