fit1446 Posted November 28, 2015 Report Share Posted November 28, 2015 have 2010 edge limited..do i have to buy conversion kits for both low beam and high beem or is there one that does both? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 28, 2015 Report Share Posted November 28, 2015 The bulbs are separate on the 2007-10's, so if you really wanted both Hi/Lo functionality, you would need 2 sets of bulbs. For example 35w Lo/55w Hi. Check with DriveBright.com to see what they have on offer. If you opt to go LED, check out vLEDs.com for their products. They have a 3,000 lumen version and a 4,800 lumen version. 1 Quote Link to comment Share on other sites More sharing options...
fit1446 Posted November 28, 2015 Author Report Share Posted November 28, 2015 The bulbs are separate on the 2007-10's, so if you really wanted both Hi/Lo functionality, you would need 2 sets of bulbs. For example 35w Lo/55w Hi. Check with DriveBright.com to see what they have on offer. If you opt to go LED, check out vLEDs.com for their products. They have a 3,000 lumen version and a 4,800 lumen version. thank you for the help Quote Link to comment Share on other sites More sharing options...
PrinzII Posted November 30, 2015 Report Share Posted November 30, 2015 When I had my 2008, I installed high and low beam 6000K 35w kits. The road would be illuminated for 1/2 mile or better. 2 Quote Link to comment Share on other sites More sharing options...
fit1446 Posted December 1, 2015 Author Report Share Posted December 1, 2015 i ordered hid should be here today...Prinzll did u install the relay with diode for the low beam? or no problems with flicker or bulb out code? Quote Link to comment Share on other sites More sharing options...
PrinzII Posted December 1, 2015 Report Share Posted December 1, 2015 Nope. Straight plug and play. The kits I used were all 35w. Quote Link to comment Share on other sites More sharing options...
