F14Snort Posted November 26, 2015 Report Share Posted November 26, 2015 I'm new to this (first time post)... I have a 2013 Edge SEL that the battery died earlier this week. I had a new battery installed, but now I can't go into ACC mode with the key to listen to the radio without the engine running. As soon as I turn it off it says "Battery Saver - System Off" "Please turn ignition off or start the engine" Anyone have a solution? Thanks!! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 26, 2015 Report Share Posted November 26, 2015 The Battery Management System (BMS) needs to be reset every time a new battery is installed on 2011+ Edges. The PCM needs to "learn" the new battery. Could also be an unrectified drain on the system somewhere, or a bad alternator. And, welcome! Quote Link to comment Share on other sites More sharing options...
F14Snort Posted December 1, 2015 Author Report Share Posted December 1, 2015 Thanks! Apparently my Edge learned its new battery and all is good. Appreciate the comment. 1 Quote Link to comment Share on other sites More sharing options...
