snowtrooper Posted November 25, 2015 Report Share Posted November 25, 2015 (edited) Hey guys I got my 12 SEL a couple months ago and the previous owner has an aftermarket remote installed from what I know. Its not the slick key fob with the push button ignition. When I click the lock button 3 times. the car turns on fully. But now when I click 3 times it turns all the way on TILL the ON part, but doesn't actually fire up and start running. It's driving me crazy trying to figure it out. Any help would be appreciated Edited November 25, 2015 by snowtrooper Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 25, 2015 Report Share Posted November 25, 2015 Without knowing the make of the remote starter it will be difficult to diagnose. You can check under the instrument panel on the driver's side for a module that might indicate the make of the starter. Also, do you have the door ajar issue? Where the vehicle still thinks the door is open? Or the "Shift to Park" issue? Where the Vehicle thinks your not in park. Both issues would probably affect the remote starter. Quote Link to comment Share on other sites More sharing options...
snowtrooper Posted November 26, 2015 Author Report Share Posted November 26, 2015 On 11/25/2015 at 4:40 AM, omar302 said: Without knowing the make of the remote starter it will be difficult to diagnose. You can check under the instrument panel on the driver's side for a module that might indicate the make of the starter. Also, do you have the door ajar issue? Where the vehicle still thinks the door is open? Or the "Shift to Park" issue? Where the Vehicle thinks your not in park. Both issues would probably affect the remote starter. No I will check over the weekend. But I don't have any of the other two issues. Will report here once I get the name of the brand Quote Link to comment Share on other sites More sharing options...
