fit1446 Posted November 25, 2015 Report Share Posted November 25, 2015 I have 2010 limited with premium sound...I installed aftermarket amp and new sub..i used the signal after the factory amp and its working I am just curious is the signal usable before the factory amp directly out of the sound dist box? there are only two leads there meaning positive and negative for sub that go into amp and convert to two channels... assuming the pre amp signal is not usable.thank you to any that can spread their knowledge. Quote Link to comment Share on other sites More sharing options...
Tribby2001 Posted December 2, 2015 Report Share Posted December 2, 2015 (edited) Not sure I understand your question. But, I would guess that you could use the mono signal before the OEM sub amp to feed an aftermarket mono sub amp.The following is the same wiring diagram as in my 2010 Edge Service Manual:http://cimg1.ibsrv.net/gimg/www.f150online.com-vbulletin/800x549/picture_php_pictureid_159482_ff3e7b44983df9ce539d23aa72d5e3f5f307fede.jpg Edited December 2, 2015 by Tribby2001 2 Quote Link to comment Share on other sites More sharing options...
