gloria's edge Posted November 22, 2015 Report Share Posted November 22, 2015 noticing lately a vibration coming from the underside coming from the front. I can feel it both on the driver and passenger side. Seems to happen while driving down the road and last only for a minute or two before I feel it again. Seems to coincide with acceleration. Hoping someone can point me in the right direction with a diagnosis. Car just turned 68k Looking forward to some feedback....Thanks! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 22, 2015 Report Share Posted November 22, 2015 AWD or FWD? Could be an underbody panel that's loose, or an exhaust pipe that's not secured, or seat bolts that need tightening, for example. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 23, 2015 Report Share Posted November 23, 2015 How do you notice it? In the steering wheel like a wheel weight? Or does it feel like the engine is shimming side-to-side when accelerating from 35 to 50 like a the inner cv joints? Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted November 23, 2015 Author Report Share Posted November 23, 2015 On 11/22/2015 at 10:45 PM, WWWPerfA_ZN0W said: AWD or FWD? Could be an underbody panel that's loose, or an exhaust pipe that's not secured, or seat bolts that need tightening, for example. Its AWD. It seems more like a drive train related vibration. Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted November 23, 2015 Author Report Share Posted November 23, 2015 On 11/23/2015 at 3:52 AM, enigma-2 said: How do you notice it? In the steering wheel like a wheel weight? Or does it feel like the engine is shimming side-to-side when accelerating from 35 to 50 like a the inner cv joints? I notice it through hearing and feeling it through the floor board. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 23, 2015 Report Share Posted November 23, 2015 Maybe the driveshaft mount bearings have gone bad? That can cause the vibration. Any vibration if you have the shifter in NEUTRAL and rev the engine to 2-2.5K rpm? The driveshaft is disengaged in NEUTRAL (and PARK also, I think). If the bearings are bad, then driveshaft replacement might be the only solution. Another option is to have the PTU & RDU fluids checked, flush & fill with new fluid if the old fluid is free of metallic debris. Maybe the seals are leaking on either end where it inserts into the PTU/RDU. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 24, 2015 Report Share Posted November 24, 2015 On addition, I would also check the axle inner C/V boot to see if it's damaged (loosing grease). Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted November 30, 2015 Author Report Share Posted November 30, 2015 May have found the problem and a solution....this past weekend the ABS, Traction Control and "Wrench" light all came on at the same time after reaching 65 on the speedometer. After slowing down and stopping the lights would clear themselves. Even though no check engine light came on I took the car to Autozone to have it scanned. It did should code C1233....wheel speed sensor. After looking in my repair and service manual this code is for the LF ABS wheel sensor. Showing it is not communicating or reading the LF (driver side front)wheel. I suspect this may be the cause of that vibration as well I've been feeling and why the lights are coming on. Decided to just replace the sensor....$33. Had to order it from my local Autozone. Should have it by today and installed. Will post an update later today or tomorrow. Hope this information helps someone..... 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 30, 2015 Report Share Posted November 30, 2015 Finally! A code to work with Good luck, looking forward to updates. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 30, 2015 Report Share Posted November 30, 2015 Curious that it's reading okay below 65 but not above. Wondering out loud... if the vibration was wheel balance, would that be enough to cause the sensor to stop reading? Or do you believe that the sensor itself is causing the vibration at speeds above 65? Quote Link to comment Share on other sites More sharing options...
akirby Posted November 30, 2015 Report Share Posted November 30, 2015 It's possible the part with the teeth that the sensor reads is damaged thus throwing the wheel out of balance at high speed and causing the sensor errors. If that's the case then replacing the sensor won't fix it. If it was the sensor itself that wouldn't cause a vibration. But it could be the sensor that is bad and the vibration is unrelated. Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 1, 2015 Author Report Share Posted December 1, 2015 Sorry to report replacing the ABS speed sensor did not solve my problem (even though I got a C1233 code) with the wrench, traction control and ABS lights coming on after traveling above 65.....since I have an extended warranty I took the car to my local Ford "stealer". I'll update everyone on their findings tomorrow. Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 1, 2015 Author Report Share Posted December 1, 2015 It's a bit odd in that I've read other threats with similar symptoms but, in my case I'm not "throwing" any other codes related to OSS and TSS sensors needing replacement. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 1, 2015 Report Share Posted December 1, 2015 If you see an ODO DATA ERROR message, def time to replace the TSS/OSS sensors. If the dealership does replace one of the two, try and get them to replace the other as well. No point in doing the work "twice". Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 1, 2015 Author Report Share Posted December 1, 2015 On 12/1/2015 at 3:57 AM, WWWPerfA_ZN0W said: If you see an ODO DATA ERROR message, def time to replace the TSS/OSS sensors. If the dealership does replace one of the two, try and get them to replace the other as well. No point in doing the work "twice". No such error message yet....that's what makes this so different from the other threads on this issue. Waiting to hear back from the dealer sometime this morning. Will post findings. Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 3, 2015 Author Report Share Posted December 3, 2015 UPDATE: Just picked up my 08 Edge. Running great now! Issue causing the problem (according to my local dealer who did the work): Left front drive shaft. I was having an issue with the traction control, ABS and Wrench light coming on after 65. The issue causing this was the tone ring went bad. Unfortunately, the entire front left drive shaft had to be replaced. The tone ring is wielded on to the shaft and the only way to replace it. What helped with the lights coming on was the ECM throw out a C1233 code. Consequently, the vibration issue I was having was related to the shaft. Now that the shaft was replaced, it runs great. Thankfully my extended warranty paid off and covered this. Was able to solve two issues for the price of one. Hope this helps someone with a similar issue! 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 3, 2015 Report Share Posted December 3, 2015 I think akirby called it on this one And ... back to enjoying the ride Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 4, 2015 Report Share Posted December 4, 2015 Would hitting a chuck hole at speed cause this? Glad ro hear everything's good to go on the Edge. Still covered by the extended warranty? That just paid for itself. Quote Link to comment Share on other sites More sharing options...
evh Posted December 4, 2015 Report Share Posted December 4, 2015 I had the exact same symptom and same solution on my right front. Yes, the ring is connected to the shaft somehow so everything needed to be replaced. 2009 AWD Edge. Mine happened at about 130,000 miles. Quote Link to comment Share on other sites More sharing options...
gloria's edge Posted December 7, 2015 Author Report Share Posted December 7, 2015 On 12/4/2015 at 12:56 AM, enigma-2 said: Would hitting a chuck hole at speed cause this? Glad ro hear everything's good to go on the Edge. Still covered by the extended warranty? That just paid for itself. Yes, I just purchased the car about a month ago with approximately 67k miles on it and was "smart" enough to buy an extended warranty. So glad I did! Quote Link to comment Share on other sites More sharing options...
FordService Posted December 8, 2015 Report Share Posted December 8, 2015 On 12/3/2015 at 9:21 PM, gloria's edge said: UPDATE: Just picked up my 08 Edge. Running great now! Issue causing the problem (according to my local dealer who did the work)...! On 12/4/2015 at 2:57 AM, evh said: I had the exact same symptom and same solution on my right front. Yes, the ring is connected to the shaft somehow so everything needed to be replaced. 2009 AWD Edge. Mine happened at about 130,000 miles. Hello Ford Fam, Thanks for sharing the great news, and your solutions! I’ll be happy to document your dealer feedback. Please PM your full name, VIN, mileage, dealer, and best daytime phone number. I’m make sure it’s noted! Tricia Quote Link to comment Share on other sites More sharing options...
