srodster Posted November 21, 2015 Report Share Posted November 21, 2015 So, after I fill the gas tank and try to start the vehicle, no luck starting it after filling. I do let the fuel pump "activate" for about 10 sec prior to trying to start it. So, I then turn the key to "off" and try again, and it fires right off on the second time. It does have the "no gas cap" feature. It also has 91k miles and has the 3.5L V6. Is this a symptom of something bigger about to happen? Never had this happen until recently, but it does it now each time I fill the gas tank. Confusing............ Quote Link to comment Share on other sites More sharing options...
srodster Posted January 25, 2016 Author Report Share Posted January 25, 2016 OK, so problem has been solved. The issue was the EVAP Purge Canister Solenoid being faulty. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 25, 2016 Report Share Posted January 25, 2016 Thanks for the update, glad the issue is fixed Quote Link to comment Share on other sites More sharing options...
