Oil change time!
13edgesport08
Depends. How long do you plan to go in between changes? OEM Motorcraft synblend is fine for shorter interval/distance OCI's. Among aftermarket full synthetics, Amsoil & Royal Purple are very popular, as is Mobil 1. If you face extreme temperatures, then you may be better off going with a 0Wxx oil than a 5Wxx oil to get easier cold weather starts.
I would look up a few Product Data Sheets (PDS's) for items of interest, compare them for viscosity index (stability through temp range) and Noack (volatility) at the very least.
Mobil1
Amsoil Signature Series 100% Synthetic Motor Oil.pdf
Castrol Edge Syntec Full Synthetic Datasheet.pdf
Motorcraft 5W30 Synthetic Blend Data Sheet.pdf
Motorcraft 5W30 Premium Synthetic Data Sheet.pdf
Pennzoil-Ultra Full Synthetic TDS.pdf
Pennzoil-Ultra-Platinum-0W-20-SN-GF-5-en-TDS.pdf
Royal Purple Full Synthetic Motor Oil Data Sheet.pdf
Royal Purple HPS Datasheet.pdf
I use Mobil 1 5w-20 full synthetic oil that has the Ford certification and have no problems so far.
I do 4k-5k oil changes,but the oil looks like it could go longer or what-ever the oil life gauge recommends(I guess about 10k miles).
If you do go with Royal Purple and still have warranty coverage on your Edge, get the API version(SAE) of the RP 5w-20 oil to meet Ford recommendations to meet warranty standards.
http://www.royalpurpleconsumer.com/wp-content/uploads/PS_API_MotorOIl.pdf
Edited by carguy75
